Old 03-09-2006, 05:13 PM   #1
Isphius
Isphius's Avatar
the wiring harness and ecu are different. there shouldnt be any problem usign the n/a block at low boost...as long as you get an oil cooler. ive also seen seperate oil coolers/tanks for superchargers, maybe you could use one of those? it comes with lines a cooler and a pump. that way you never even need to tap into the block or heat up the engine oil. also the lower compression pistons help a lot to prevent detonation. about 8:1 would be perfect if you can find those. Im sure the motor doesnt have an oiling problem, my motor has 186k miles on it and it still has about 28-30 psi of oil pressure once its warm. lol.
Old 03-10-2006, 08:12 AM   #2
rnoswal
rnoswal's Avatar
You are right about the oiling systems in the engines, they are good. The thing with the oil squirters in the turbo engine is that they are used for cooling the pistons even more than the oil holes in the rods. The cooler and the lines help keep the oil cooler ever so slightly and really are there to help transfer some of the heat from the pistons under long boosts or hard boosts.
Use a synthetic oil in the engine and that will help too. I try to use the old 10 psi per 1000 rpms guage with oil pressures. Everyday driver cars usually don't quite make it, but should be close. A manual guage is best for keeping track of that.
Suprra girl told of an N/A with a turbo and stock N/A compression. Just keep the max boost down a little more. Instead of 15, go for 8. The N/A revs up so much quicker because of the compresion, but I just don't know if the stock N/A pistons can handle the abuse. Maybe a quality aftermarket piston, but most go for lower initial compression, but it is not a rule. More compression equals more power, just watch for detonation and use very good fuel and make sure your knock sensors are working. That is why the turbo engine has 2 of them and the N/A only has 1.
Russ
Old 03-11-2006, 04:43 PM   #3
Takahashi_46
Takahashi_46 is on a distinguished road
So since the turbo block more oil valves what do people do that do bolt on turbos to there n/a blocks? how do they get more oil cooling? Also one of you guys said that both n/a and turbo motors have the oil squirters just one hase more than the other?
Takahashi_46 is offline   Reply With Quote
7MGE to 1JZGTE engine swap help please! seek102287 Non-Generation Specific Questions 2 07-02-2007 12:57 AM
7mgte and 7mge question supraman121 MKIII Supra 2 01-12-2007 09:09 PM
7mge to 7mgte kallmijonx2 MKIII Supra 2 10-22-2006 12:55 PM
7mge vs. 7mgte KNYFE MKIII Supra 3 09-27-2005 02:21 PM
