#11 |
suprra_girl you're a kiwi right ? where can i get an accordian hose from ? toyota told me a couple hundred dollars and three weeks from japan.
i'm on my second one right now. its from a wrecked car and way better than the origonal one ... it's just cracked, not broken off in chunks and glued back up
So I bought this old Honda bike, an NSR250. Bit of a street racer, I guess. I'm told they're fast. Delivering it home with a friend driving the Supra for the first time. I drop gears and make a scream from the twin pipes flowing down this pony's flanks and it takes off like it's tail's on fire. I look back when the Honda gets to its tap-out and the Supra's only two lengths behind. No one I've let ride my bike has told me its slow, they've all loved the thing. That car is a good thing indeed. Last edited by lethalwithasupra; 03-02-2006 at 07:03 AM. Reason: adding a note |
#12 |
dont get that ugly acordian hose! lol....i just went to a local import shop and got a 96-00 civic intake pipe and cut it. and the old ugly acordian hose is no longer there. it is now a nice shiney intake pipe! it cost me 60 bucks for the pipe and like 3 bucks for the 3inch coupler
#13 |
cool. was thinking of mothering something after-market in there for an intake and pod filter
picture me muttering " need ... 3" ... exhaust " all my waking hours and " need ... pod ... filter ... " when i sleep
So I bought this old Honda bike, an NSR250. Bit of a street racer, I guess. I'm told they're fast. Delivering it home with a friend driving the Supra for the first time. I drop gears and make a scream from the twin pipes flowing down this pony's flanks and it takes off like it's tail's on fire. I look back when the Honda gets to its tap-out and the Supra's only two lengths behind. No one I've let ride my bike has told me its slow, they've all loved the thing. That car is a good thing indeed. |
#14 |
what year lexus's do i get teh AFM from??????
88 Turbo Targa |
#15 |
don't forget that the accordian hose has the 3 plumbback holes in it for various breathers
i think i could get a new accordian for about $100 from toyota if you like you can pm me if you are serious and i'll get a firm price for you tomorrow i believe the afm from any 1uzfe lexus v8 is the one you are after
#16 |
I have a 87 turbo supra with full 3 inch exhaust 12 psi of boost, adjustable fuel regulator. Every time I run my engine up to 5,000 rpm, it starts acting like a rev limiter but no check engine light is on, is that my fuel cut. The only sensor I don't have on my car is a turbo boost sensor, I thought it was only used for the cluster boost gauge. It also did it at 9 psi so I have no clue what it is. The only code I got is a boost pressure signal, it don't sound like I have boost leak.
#17 |
sorry to disturb this flow,
but i askd this question and never had a response b4 but what actually happens if you hit fuel cut? and whats the worst that can happen when you hit fuel cut? and does mk3's come with speed limiters?
#18 |
the worst that could happen is you would shit your pants when you hit FCO for the 1st time
the engine cuts out for about 1/2 a second then resumes
#19 | |
#20 |
gomez, no you aren't hitting fuel cut, do a diagnostic and make sure you don't have any other problems
fuel cut has been described as hitting a brick wall it is extremely violent lol supra2nr: LOL i know what you mean, it's not the best feeling, ya just gotta think... is this actually ok for the engine to cut this violently... i think it best to turn boost down a bit to avoid it because constant triggering of fuel cut can't be good lol
| supra head gasket questions+ rebuild | Andy C | MKIII Supra | 169 | 05-18-2010 01:59 AM |
| Fuel pump relay and pressure. | carfanatic89 | MKIII Supra | 8 | 05-01-2008 06:39 PM |
| Testing for bad ECU, &/or bad Fuel Pump | elliotl | MKIII Supra | 0 | 08-21-2007 10:42 PM |
| fuel cut defender turbo xs | joel williams | MKIII Supra | 8 | 08-21-2005 09:22 PM |
