Old 03-02-2006, 07:01 AM   #11
lethalwithasupra
Default related side-note ;
suprra_girl you're a kiwi right ? where can i get an accordian hose from ? toyota told me a couple hundred dollars and three weeks from japan.
i'm on my second one right now. its from a wrecked car and way better than the origonal one ... it's just cracked, not broken off in chunks and glued back up
Old 03-02-2006, 09:50 AM   #12
kewlcoconut
dont get that ugly acordian hose! lol....i just went to a local import shop and got a 96-00 civic intake pipe and cut it. and the old ugly acordian hose is no longer there. it is now a nice shiney intake pipe! it cost me 60 bucks for the pipe and like 3 bucks for the 3inch coupler
Old 03-03-2006, 06:06 AM   #13
lethalwithasupra
cool. was thinking of mothering something after-market in there for an intake and pod filter
picture me muttering " need ... 3" ... exhaust " all my waking hours and " need ... pod ... filter ... " when i sleep
Old 04-04-2006, 05:32 AM   #14
spoolin1
spoolin1's Avatar
spoolin1 is on a distinguished road
what year lexus's do i get teh AFM from??????
88 Turbo Targa
spoolin1 is offline   Reply With Quote
Old 04-04-2006, 11:24 AM   #15
don't forget that the accordian hose has the 3 plumbback holes in it for various breathers
i think i could get a new accordian for about $100 from toyota
if you like you can pm me if you are serious and i'll get a firm price for you tomorrow
i believe the afm from any 1uzfe lexus v8 is the one you are after
Old 09-24-2006, 06:09 PM   #16
gomezmk
I have a 87 turbo supra with full 3 inch exhaust 12 psi of boost, adjustable fuel regulator. Every time I run my engine up to 5,000 rpm, it starts acting like a rev limiter but no check engine light is on, is that my fuel cut. The only sensor I don't have on my car is a turbo boost sensor, I thought it was only used for the cluster boost gauge. It also did it at 9 psi so I have no clue what it is. The only code I got is a boost pressure signal, it don't sound like I have boost leak.
Old 09-25-2006, 01:26 AM   #17
Supra2NR
Supra2NR's Avatar
sorry to disturb this flow,
but i askd this question and never had a response b4
but what actually happens if you hit fuel cut?
and whats the worst that can happen when you hit fuel cut?
and does mk3's come with speed limiters?
Old 09-25-2006, 08:43 PM   #18
Cool
the worst that could happen is you would shit your pants when you hit FCO for the 1st time
the engine cuts out for about 1/2 a second then resumes
Old 09-26-2006, 04:33 AM   #19
Supra2NR
Supra2NR's Avatar
why does this scare me more than the thought of my engine exploding?
Old 09-26-2006, 09:38 AM   #20
gomez, no you aren't hitting fuel cut, do a diagnostic and make sure you don't have any other problems
fuel cut has been described as hitting a brick wall
it is extremely violent lol
supra2nr: LOL i know what you mean, it's not the best feeling, ya just gotta think... is this actually ok for the engine to cut this violently... i think it best to turn boost down a bit to avoid it because constant triggering of fuel cut can't be good lol
fuel cut defender turbo xs joel williams MKIII Supra 8 08-21-2005 09:22 PM
