Old 05-24-2007, 03:33 PM   #11
Talking
Originally Posted by mattfurlani
I bought loaded calipers instead of trying to redo all the cylinders. I found something funny. You can accdentally (by not readint the big 'r' and 'l' on the caliper) put them on upside down in the front.
Needless tosay it took me many days to figure itout.
I'll never under estimate my own stupidity again.
This was not known, and made me laugh out loud !
Old 05-24-2007, 03:44 PM   #12
mattfurlani
mattfurlani is on a distinguished road
this was a non abs type too.. perhaps that was partially the problem
Its broke, it could be anything, and cost of repairs will greatly exceed the value of the car
mattfurlani is offline   Reply With Quote
Old 05-24-2007, 06:54 PM   #13
dannydavi
dannydavi's Avatar
well if your just replacing the break 'pads' then you can get them all at your local parts store for under 100 bucks. then it's as simple as they said, you take off the wheel, loosen the lower caliper bolt, twist up, remove old pads, depress caliper with c clamp or channel locks, might want to release the bleeder screw, put new pads in, place over rotor, tighten caliper bolt, then test them bad boys.
'86.5 Supra - A/T - N/A - JDM
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Old 05-24-2007, 07:14 PM   #14
ebang
it's not always that easy.......I removed the wheel and the lower caliper bolt...but the caliper would not budge (slide up)...seems that the top bolt that is supposed to swivel was seized up...I had to hammer the caliper up and take the whole assembly off...then again hammer the caliper off the part the holds the pads on the rotors...grease all parts and put back together...( oh yeah had to get new top caliper bolts cuz the hammering bent the old ones)..this was for both sides...now i had to bleed them...well the bleeder screws were rusted to hell and both broke off...removed all parts again and drilled off the broken bleeder screws...made sure the thread were fine...one was good and tapped the other. I ordered new bleeder screws and will be back at it again tonight...
1987 N/A Targa 5 speed
no mods as yet
Old 05-24-2007, 07:16 PM   #15
dannydavi
dannydavi's Avatar
man that must have been one dirty brake system, if all those things were seized and breaking, that sucks, well looks like your handling it just fine by replacing all neccessary things. good luck.
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Old 05-24-2007, 07:22 PM   #16
ebang
yeah it is something alright!!...it is going to be three afternoons with a total of 15hours and hopefully I can get the 2 front ones done....then it is time for the back...lol....I just got this car in February it was bought as is so alot of work is needed
no mods as yet
Old 05-25-2007, 12:43 AM   #17
mattfurlani
do you have abs?
I replaced almost everything on my car with no lift and it took me like 10 hours...
Also
NEVER BUY THE 10mm Flare wrench from NAPA
ITs shitty... I found that out the hard way...
part of my gas tank shield is missing
