Old 02-21-2006, 04:33 AM   #1
noa324
noa324 is on a distinguished road
Default fucked up my mk3
my mk3 is making the worst noise.......... its like the rod has let go of the crank and is floating around...... i was doining around 100 mph & blue smoke came out the car thought it was a headgasket its not pretty sure the piston bearing or crank bearing is fucked do this shit go bad alot the bearing was pretty old but not scratched or messed up.....
noa324 is offline   Reply With Quote
Old 02-21-2006, 04:59 AM   #2
rnoswal
rnoswal's Avatar
Sounds like time to replace the engine. Did it put a hole in the block? Also, and we have had this discussion with others, it is very hard to read your message because of not having any punctuation. We don't need capital letters but periods help a lot when you are changing to a different item.
If it is rattling real loud and running on less than all 6 cylinders, then it is time for a tear down or let someone who knows engines listen to it. Blown engines are blown engines with the same consequences. Probably your oil was low and spun a bearing, then it seized and broke internally. Expensive and very time consuming unless you know where a good used engine is for a decent price.
Let us know how it goes.
Russ
Old 02-21-2006, 05:28 AM   #3
noa324
i know there is no hole in the block and the motor didnt cease up... there was plenty of oil in the car could of spun a bearing.... i dont know about u guys but in miami 7mgte go for 800 to 1500 $ i got my last one for 800$
Old 02-21-2006, 11:35 AM   #4
stumpjumper
stumpjumper is on a distinguished road
YOu must have revved 'er too high. Look on ebay. $400 to 600, shipped.
stumpjumper is offline   Reply With Quote
Old 02-21-2006, 06:16 PM   #5
j3pz
??? im on ebay all the time and never have a seen a 7mgte go that low unless it was out of a parting out car or has 100k+ miles. the low mileage ones go for 800-1200. if you see any more of those 400-600 ones, send me a pm...
Old 02-21-2006, 11:10 PM   #6
stumpjumper
I was just looking on ebay a minute ago and I searched for 7mge in ebay motors and a few came up. One was for $499 and it said low mileage. They are the japan low mileage engines. You can also go to the wholesale importers and find one for $500. Those places have hundreds of 30-50K mile engines and tranny's. I live in Chico, Ca and there is a place here that sells 'em at $600. In the los angeles area is where you can get the real deals...
Old 02-22-2006, 02:19 AM   #7
dcrusupra
dcrusupra's Avatar
He means GTE dude, not GE. Yes, the non turbo engines go from like $200-600. Low mileage turbo engines go from $700-2000. Maybe less. You might get lucky. Although there is one on ebay right now for 850 shipped.
Here's the link.
USDM 7M-GTE
New Rebuild
My CarDomain
Old 02-22-2006, 03:08 AM   #8
noa324
well back to the car i was at like 4500 rpm so i didnt rev to high it happened though when i let go of the gas so maybe that has a factor... w/e the motor i got for 800$ was a rebuild 7mgte and it was in a gas station for 2 years i got lucky
i fucked up ir3z3k13l MKII Supra 2 02-27-2006 11:35 PM
