Old 02-28-2006, 06:30 PM   #21
hangsupra
for the civic you gonna race is it a hatchback or is a 2door couple... i pretty sure u will beat the hatch... back in the day when i just swapt my mk2 auto to manual... i race with the 94-95 civic coupe i beat it.... but hope you can beat it... just try your best at launch... thats all you need it for the supra... dont worry for high end.. just wondering for the launch only.... cause supra is kind of slow at laugh if you were stock... but high end or at high speed i sure you will beat it or catch up with it...
Old 03-02-2006, 02:01 PM   #22
brs86supra
brs86supra is on a distinguished road
the civic is a coupe so do i have a chance. found out that it isnt oil it is radiator fluid, but it is leaking where the oil pan is where could it be coming from?
brs86supra is offline   Reply With Quote
Old 03-02-2006, 02:04 PM   #23
rnoswal
rnoswal's Avatar
Waterpump, any of the hoses behind the thermostat or even a freeze plug.
Russ
Old 03-02-2006, 02:15 PM   #24
brs86supra
thought it could of been the water pump, but how do i tell if it is, if it is about how much would one coast. also what is the VSV i saw it in the manual it connects to the thermostat housing and its supposed to have a hose going to it what is it. and there is also a rubber hose on my intake one connects to the intake and the other goes from the intake( both are where the air filter are near the air filter) what does the one going from the intake go to
Old 03-02-2006, 07:01 PM   #25
dcrusupra
dcrusupra's Avatar
Oil and radiator fluid look nothing alike. Radiator fluid is neon green and oil is well, oil colored. It should be fairly easy to tell what it is.
Not sure about the Thermo housing but the rubber lines goes from the charcoal canister to the intake then from the intake to the throttle body. Ill have a picture up in a few mins.
New Rebuild
My CarDomain
Old 03-02-2006, 09:17 PM   #26
rnoswal
rnoswal's Avatar
Water pumps go for around 30 to 40 bucks. Behind the water pump there are a couple of hoses that go to the turbo housing and that go to the heater. The two on top, one comes from the exit of the heater core and the other goes to the intake manifold just behind the alternator. The charcoal cannister is just a vent for the fuel tank.
The hoses behing the thermostat housing are notorious for leaking and even blowing. The get oit on them and it gets hot in that area too.
The water pump is easy. Remove fan shroud lower piece then slide the whole shroud off. Unbolt the clutch fan after loosening the belt, alternator, take off the pulley on the water pump. The pump itself has about 7 or 8 bolts, mostly 10 mm but a couple of 12 mm. Take out the bolts then take off the pump. You may have to tap the pump a few times to get it to break its seal. Clean the old gasket off and reverse this precedure to put back on.
Check under the pump to see if it has a drop or residue of water/antifreeze from the bypass hole or if the shaft wiggles up and down or is stiff to turn.
Let us know
Russ
Old 03-06-2006, 01:03 PM   #27
brs86supra
fixed my leak it was an antifreeze leak, it was leaking from the bypass valve. now i am ready to roll, might of found a turbo supra with motor but the car doesnt run, wondering how hard it would be to take the turbo off that car and puttinb it on my supra, mine of course is a n/a auto and was wondering what else would i need to install it on mine? so if so could someone please help me with this information i will gladly apreciate it, i will also be doing some research of my own.
Old 03-06-2006, 07:13 PM   #28
dcrusupra
dcrusupra's Avatar
Lets get the obvious out of the way......Turbo, turbo manifold, intercooler, and intercooler piping, and BOV. Then we move on to the oil cooler and oil cooler piping, throttle body, and throttle body linkage, and downpipe. Thats about all I can think of right now. You won't be able to boost as much because the compression is higher on an N/A engine. You would only be able to boost about 9 psi. A lot of people say it's easier to just swap in a turbo engine. In which i agree. But its a matter of opinion and it doesnt matter what other people say because they arent driving it. You are. Good luck with what ur doing and good luck with ur research.
New Rebuild
My CarDomain
Old 03-13-2006, 01:14 PM   #29
brs86supra
got my exhaust the other day, got a 2 1/4" catback with a Lawson Muffler 2 1/4" inlet and 4" outlet. how good is this muffler dont really know much about them. i can feel a little difference in acceleration, but i do want to change to cold air, but i cant find any cold air kits for the supra where can i find one. any solutions?
Old 03-13-2006, 04:38 PM   #30
Troyota
Troyota is on a distinguished road
There really is no room for a Cold Air kit in the Supra...look around the intake area...there is no space to get the necessary piping and air filter close to the ground where most cold air kits go to...the only real options are to either cut a hole in the body somewhere to allow a fitler to be placed say in the fender well or in the front bumper. Another option is to try and route a pipe through the little hole that is behind the pass. headlight. The best bet is to put a standard intake on that reaches to the front and maybe build a box to try and keep as much hot engine air out of the system.
1987 N/A MA70 Supra <--1JZ swap in progress
1986 AE86 GT-S Hatchback
2002 DC5 RSX Type S
Troyota is offline   Reply With Quote
