Old 02-11-2006, 05:11 AM   #1
XtreeX
XtreeX is on a distinguished road
Default K&N Fuel Injection Kit
Works w/Original Equipment Manufacturer Computer Systems
Replaces OEM Filter and Air Box
Better Acceleration-Increases Power (up to a 26 HP gain)
Lasts up to 50,000 Miles Before Service is Required - Filters are Washable/Reusable
10 Year/ Million Mile Limited Warranty
This kit i found is only $170 bucks and if it increases hp by 15 i consider that pretty good. Any NA supras run with this, or can vouch for it? The stuff above is straight from K & N. 26 HP seems like alot, can it really make this big of a difference?
XtreeX is offline   Reply With Quote
Old 02-11-2006, 05:20 PM   #2
kewlcoconut
this kit isnt that bad. i have it on my supra at the moment. the one thing that i noticed with mine was increase in gas mileage and better acceleration. if you really want it to perform, find a way to somehow tuck that baby under the passenger headlight, so it sucks up the cold air. because the way it sits in the engine bay, it getting a bit of cold and hot. it would perform a lot better. but all in all, i would recommend it.
Old 02-11-2006, 09:54 PM   #3
rnoswal
rnoswal's Avatar
I watched a Two Guy Garage the other day. They started with an early model Chevy pickup, 305 V-8, 202 torque. They added a set of headers, a throttle body spacer (1") and a cold air system. That was it and the torque figures jumped a total of 75 ft lbs. The headers were good for 30 of that. Try some of this on the N/A and see what happens.
Russ
Old 02-12-2006, 12:06 AM   #4
joel w
joel w's Avatar
make sure thats for your car as , it seems a bit steep in price like it may be for a turbo as they are bigger diameter.... ive seen lots of K&N filter kits for N/A's on ebay for around $45 shipped..?? link it for us...
Old 02-12-2006, 08:55 PM   #5
j3pz
ive seen in some magezines some cars got an shitter fan exhaust hoses goin from the grill to right up to the intake, brings in the cold air from outside and they are really light, if you could find some way to put on in there... need i explain more?
fuel pump mounting bracket GremlinMKIII MKIII Supra 4 09-06-2007 07:08 AM
Fuel Octane scruffboy Non-Generation Specific Questions 3 09-08-2006 06:49 PM
