Old 02-09-2006, 08:08 AM   #1
ryemann32
ryemann32's Avatar
ryemann32 is on a distinguished road
Default fought with it all night
does anyone who the secret to putting in a 5 speed had know problem getting it out but it refuses to go back in. So does anyone have a secret they want to share
ryemann32 is offline   Reply With Quote
Old 02-09-2006, 08:15 AM   #2
1988gte
hmmm im doing the same thing tomorrow. did you do it like tsrm says (clutch disc, cover, on input shaft) or cant you just put on the clutch on the flywheel with the alinment tool like most transmissions? or no and why anybody
Old 02-14-2006, 04:26 AM   #3
djalkyd
djalkyd's Avatar
djalkyd is on a distinguished road
i just did a clutch swap on my 87 turbo. i had the biggest problem getting it back in. here is what i did, be warned, you need small hands to do this if you do it my way.
unbolted the bellhousing from the tranny then bolt the bell housing to the engine first. this will help you get the starter back on also.
then put the trans back onto the bellhousing, be very careful that you line it up exactly right because it is almost like a press fit coming off and it is a little harder lining it up. just jiggle it a bit and it will line up on the dowls and pop right in.
now the hard part. there are 9 bolts that hold the tranny to the bell housing. going through the 2 slots on the sides of the bell housing, thread in all the bolts as far as you can then use a 1/4 inch drive ratched to tighten them as far as you can.
now the lovely torque wrench to get your final torque. use a swivel head and long extension to get them all torqued back.
it took me a few hours under a lift. 2 of those hours spent on trying to get the entire tranny back in with the bell housing on and the final hour doing it the way i just said.
i know it sounds backwards but it worked a whole lot easier than fighting the entire tranny.
if anyone has a better way, i am all ears for future reference.
djalkyd is offline   Reply With Quote
Old 02-14-2006, 05:34 AM   #4
1988gte
okay i got it done! the trick is just tilt the engine a little so the back goes down ( used a small hydro jack) after i did this it took 10 seconds to stab in.
Old 02-14-2006, 05:59 AM   #5
djalkyd
djalkyd's Avatar
man i tried that forever. it seemed like i couldnt get enough tilt on the engine. i put in a stage 3 clutch so that should'nt have made to much of a difference.
oh well, i went around my "A" hole to get to my elbow.
Old 02-14-2006, 06:56 PM   #6
1988gte
at least its done So hows the clutch feel? i got air in the lines and has trouble grabbing reverse, going to bleed it again today after work.
bhg suprakid91 MKIII Supra 54 10-07-2008 03:49 PM
