Old 02-13-2006, 09:32 AM   #11
lethalwithasupra
heh ... here's a good question ... is the MANUAL button pressed ? MANU will glow on the dash. cos if that's pressed it'll select exactly the gear you tell it to instead of climbing through them ... ?
Old 02-14-2006, 12:13 AM   #12
darkzebra
darkzebra is on a distinguished road
Default Really SLOW acceleration under D
I appreciate all the response.
Will try the various things tomorrow afternoon and provide feedback
darkzebra is offline   Reply With Quote
Old 02-14-2006, 12:13 AM   #13
^^^^Supras don't work like that. The only button option is OD on/off.
Old 02-16-2006, 01:17 PM   #14
darkzebra
Default Really slow acceleration under D
1. The car revs past 5K, smoothly, without any misfire or backfire. Does not seem like exhaust is blocked, or ignition or fuel problem. In fact it tears away (for an automatic) in reverse.
2. If I start in L and accelerate then shift to D the acceleration drops immediately.
3. In 2 it just stays there, does not double shift.
I guess I will have to take it to a tranny shop and keep my fingers crossed that they know about this car. Most likely I would have to change tranny, in which case I may consider swapping to manual, which I am sure my son would love.
Anyone has a manual tranny, or the necessary accessories for the switch, for sale? I live in the NY capital (Albany) region.
Thanks again for your response and help
Old 02-17-2006, 03:00 AM   #15
djalkyd
djalkyd's Avatar
djalkyd is on a distinguished road
shift solenoids may not be the problem. it sounds to me like the manual valve is sticking or the 1-2 or 2-3 shift valve in the valve body. it could also be a stuck checkball to where you are not getting fluid flow to those valves for that shift.
now you say you have 1st and 2nd manual but not 3rd or overdrive. it could be an over running clutch or an actual clutch pack itself. how did the tranny fluid look and smell? if it is dark brown and smells burnt then the clutch packs could be going out.
can you rev it high in D but not get any movement? if so then the clutches are going bad or an actual over running clutch and bearing is going bad. then you would need a rebuild.
if it is the manual valve, try and adjust the manual linkage from the shifter to the tranny and see if you get more movement out of it.
try flushing the tranny first and go from there.
djalkyd is offline   Reply With Quote
Old 03-08-2006, 03:44 AM   #16
jbrad1
jbrad1 is on a distinguished road
I have a 89 Turbo Auto. i had the same problem is feels like the car is starting of in maybe 3rd gear replace the shift solenoids and fix the problem. i do not remeber exactly which ones was bad. But the solenoid cost me about 115 dollars at the dealer. They use a on off pattern to shift so if they both go bad then it is a fail safe to stay in 3rd gear. It almost felt like you have the e brake on or something its so bad. also you pull it down in first gear manually it dpes better but still didnt seem to have the power it should have./
jbrad1 is offline   Reply With Quote
Old 03-19-2006, 05:07 AM   #17
djalkyd
djalkyd's Avatar
did the solenoids fix the problem or is it still acting up?
Old 04-12-2006, 11:36 PM   #18
gujuguy1983
gujuguy1983 is on a distinguished road
i have same problem with my 1998 camry LE. in D drive its pick up is too slow and its like jurk too me,
if anyone know how to take care of that at home bymyself then plz lat me know about it........i like to done wiht this problem as soon as i can.
gujuguy1983 is offline   Reply With Quote
Old 04-13-2006, 04:38 AM   #19
Isphius
Isphius's Avatar
I know with GM transmissions a clogged torque converter and/or filter can cause things like that. My monte carlo would stick in first and 2nd gear at the same time when it got hot, (which means the wheels lock violently) cause the TC was clogged up. That usually happens from forgetting filter/fluid changes. It also made the car start in 2nd gear or not shift into 3rd sometimesk,and made the shifts really mushy. And OD never worked anyway. I changed the TC and filter and rebuilt the valve body anyway and it shifted like a manual power shifting, chirped 2nd and all. I have no idea if this applies to toyota trannies, but im sure there operation is somewhat the same.
push down pedal - slow acceleration (HELP!) hockeygott MKIII Supra 7 06-30-2008 05:40 PM
Slow Start jaysun MKIII Supra 5 09-18-2006 07:36 AM
Super Slow on D, L and 2 ok ram5757 MKIII Supra 1 04-20-2006 06:15 AM
slow acceleration 87supraguy MKIII Supra 2 03-19-2005 07:47 AM
