Old 01-26-2006, 10:27 PM   #1
lilsmitty
lilsmitty is on a distinguished road
Default alarm....
Stock alarm went off and i was no where near my car, Now i have no power watsoever. But my battery is fine cuz my neons are ran directly to them and they work fine i have no lights no ignition lights or sound. nothing at all. i tried unhookin my battery but that didnt do anything....any help?
lilsmitty is offline   Reply With Quote
Old 01-26-2006, 10:42 PM   #2
joel w
joel w's Avatar
sounds like something drained your battery down??, i think the alarm going off is common when voltage drops below a certain level..??
Old 01-27-2006, 01:45 AM   #3
mrnickleye
mrnickleye's Avatar
When the factory alarm comes on, it will honk the horn, and flash the lights for a few minutes, then stop. The electrical power may be disconnected. NORMALLY...put the key into the door lock, and lock-unlock it, and it should reset.
Maybe you have to turn the key in the same direction 2x.
There have been several threads on the alarm systems. Perhaps if it is still acting up, the answer may be found in one of those threads.
Old 01-30-2006, 03:31 AM   #4
lilsmitty
WHy would it tottaly shut off all the power in my car though? I mean everything is dead. when i turn the key no lights on the dash come on nothing. no tail lights and headlights no dome lights nothing????? and the battery is good....
Old 02-01-2006, 02:28 AM   #5
mrnickleye
mrnickleye's Avatar
Perhaps the alarm system has a problem as such would blow a fuse, or circuit breaker ? It should only honk and flash lights, then quit.
Old 02-02-2006, 02:45 AM   #6
lilsmitty
OMG someone poped my hood and tottaly tore off my power cable like the one side was still on but the other was still connected... assholes
1989 Supra alarm help... :( sizzor Non-Generation Specific Questions 8 11-07-2009 05:30 PM
alarm? starter? dunno help plz Scionguy MKIII Supra 3 11-04-2008 08:35 PM
Car alarm with a mind of its own suprascoot MKIII Supra 10 03-08-2008 11:09 PM
the right way to disable your car alarm and still be able to drive. ogkush Car Audio and Alarms 0 02-06-2007 02:04 AM
Alarm MICAHMOBERLY Non-Generation Specific Questions 5 08-27-2006 10:00 PM
