Old 01-18-2006, 10:26 PM   #1
Tortilla
Tortilla is on a distinguished road
Default power windows
I recently purchased an '89 supra. The car was really well kept, but it does have a few small problems. one of them is that the passenger window does not go down. The guy who owned it before me had the $250 window motor replaced and that didn't fix the problem. I've read that if the driver side window switch is bad for some reason the passenger side won't work either, can anyone confirm this?
Thanks.
Tortilla is offline   Reply With Quote
Old 01-18-2006, 10:37 PM   #2
joel w
joel w's Avatar
its a common problem, read this
http://www.supras.com/06/techcenter/...5414c12a8f69c8
Old 01-19-2006, 03:12 PM   #3
Tortilla
Originally Posted by joel williams
that's some excellent info, but my switch doesn't work on passenger side nor drivers side for the passenger window. drivers side window works fine.
Old 01-19-2006, 04:20 PM   #4
joel w
joel w's Avatar
well try the link i gave you on one switch, see if it works, the problem could be that the switches never get used nearly as much as the drivers window switch, rain or moisture corrodes the switch... just a thought, the same thing you described was wrong with my car, it fixed it, let us know..
Old 01-22-2006, 12:46 AM   #5
Tortilla
well it was the driver side switch contacts that was messing up. unfortunately the driver side switch isn't nearly as easy to take apart as the passenger side, so i couldn't clean the "anvils" on it. But I can confirm that if the driver side contacts are bad then the passenger side switch won't work either. For now both windows are working though
Old 01-22-2006, 02:07 AM   #6
joel w
joel w's Avatar
well good deal, glad you located the problem..
Greetings! importauto Import Auto Center 7 06-21-2009 07:42 AM
no spark chrism8799 MKII Supra 6 12-08-2008 12:38 AM
6 point Roll Cage? carl johansson Road Racing & Autocross 0 12-01-2007 12:28 AM
Power Windows are so sloooooowwwwwa! GTE89 MKIII Supra 6 12-12-2006 06:44 AM
Lsd RussianMK3 Drifting 6 12-10-2006 05:42 PM
