Old 01-12-2006, 12:44 PM   #11
rnoswal
rnoswal's Avatar
If you want to you can gut the thermostat. The thermostat helps get the engine warmed up quicker and won't run rich as long. Removing the insides of the thermostat will slow down the water enough to keep it in the engine and radiator and keep it close to the right temp. You might be able to experiment with the different size washers too. It is a racers trick so you have the restriction but don't have to worry about a thermstat not opening and causing a major problem.The thermostat is almost constantly moving to keep the temp set at what the temp is supposed to, but as you will notice, there are several different heat ranges to choose from so it is not that critical. I have had other, older cars without a thermostat and they really ran cold, but I have heard the opposite from others with other types of cars.
Computer cars need to be in the range of offered temps of thermostats to run the engine effeciently so run something in there at least!
Let us know how it works.
Russ
Old 01-12-2006, 03:27 PM   #12
Bullz_EyE
Bullz_EyE's Avatar
Bullz_EyE is on a distinguished road
I bought a Genuine Toyota thermostat yesterday, it will be installed.
Function Over Form - Form Follows Function
88 MkIII Jurbo
Bullz_EyE is offline   Reply With Quote
Old 01-12-2006, 05:41 PM   #13
Suprageezer
Suprageezer is on a distinguished road
YES, you certainly need a Thermostat for even cylinder wear, stable oil tempratures, and stable control of your engine by your ECU. I added a link to better edumacate folks who think running no thermostat is ok. I too live in San Diego and right now when I leave for work it's darn chilly so I need heat asap for myself not just the engine.
Geezer
http://www.centuryperformance.com/coolingsys.asp
Suprageezer is offline   Reply With Quote
Old 01-19-2006, 07:48 AM   #14
sd88supra
sd88supra is on a distinguished road
i was gonna also say to get a thermostat. my mk2 thanked me for getting it a new one when i still had it and my mk3 is gonna thank me tomorrow for putting in a new one.
and it is nice not having to store our babies for winter (im from sd too)
sd88supra is offline   Reply With Quote
Old 01-19-2006, 08:28 AM   #15
Strannik
Strannik is on a distinguished road
pretty much w/o thermostat your engine runs cold for longer, so it takes longer for all the metal parts to expand and take their places -> you increase the wear on the piston rings etc...
Strannik is offline   Reply With Quote
Old 01-19-2006, 02:41 PM   #16
Bullz_EyE
Bullz_EyE's Avatar
Scratch experiment 1. Good info. Thanks.
88 MkIII Jurbo
Old 01-02-2007, 12:12 AM   #17
Zipakna
Zipakna is on a distinguished road
Default Re: Thermostat Necessary?
i realize this reply is very very late, but, thought id post anyways.
Get the Thermostat!!! if you dont that funnly little valve (at least on the 7MGTE(turbo)) that has two little hoses on it will not open costing much more in gas. the tempurature opens a valve to the Evap Canister. you can lose up to 5 miles per gallon maybe more if you dont use one. i learned that driving from san fransico to virginia beach, 3129 miles. with thermostat 10-11 gas tanks. without thermostat 13-14 gas tank fulls of supreme gas, mainly from exon or Love's Truck Stops. my supra has made that trip 8 times....so far
Zipakna is offline   Reply With Quote
installing thermostat sd88supra MKIII Supra 8 06-18-2010 02:23 AM
Thermostat SilenceboneSupra MKIII Supra 2 12-01-2007 06:37 AM
Which Thermostat? scruffboy Non-Generation Specific Questions 4 03-01-2007 11:18 AM
Checking Thermostat scruffboy Non-Generation Specific Questions 6 03-09-2006 05:49 PM
Thermostat??? kewlcoconut MKIII Supra 2 12-24-2005 08:37 PM
