Old 01-26-2005, 06:28 AM   #1
JMoses
JMoses is on a distinguished road
I just recently changed my cluster over to white and now my speedometer is off my 20 mph, is there an easy fix?!? Help!!
JMoses is offline   Reply With Quote
Old 01-26-2005, 09:42 AM   #2
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
unfortunately believe it or not i haven't had experience with analogue dashes before lol... most of ours are digital... hopefully someone here can help ya out
Pics of my build.
Do a diagnostic first!
Old 01-26-2005, 06:25 PM   #3
supracw
supracw is on a distinguished road
well if you akcidently moved the needle around upon the install you may have damaged it witch there is no easy fix.alos i would try to look at the speeddo cable cuz you may not have installed that correctly. so i would check that first.
supracw is offline   Reply With Quote
Old 01-30-2005, 09:31 PM   #4
hangsupra
if i were you i will untight both side of the speed cable from the dashboard and the other end of the cable where it conect to the trainny... and spin the inner cable from either end of the speed cable and see if it twist/spend. if it doest spind/twist smoothly than raplace the whole cable with a new one or an use from from the junk. also check the adapter from the trainny where the end of the speed cable connect to the trainny sometime it just need to be adjust tho. hope it work....
speedometer drive gear removal Gunnar MKIII Supra 1 01-20-2008 08:24 PM
Speedometer and boostgauge not working Gunnar MKIII Supra 0 10-20-2007 08:17 PM
Speedometer, High RPM/Speed whine, High HC's 88 N/A ravenmaster MKIII Supra 8 08-13-2006 12:02 AM
Speedometer help HottScennessey MKIII Supra 1 03-19-2005 06:59 AM
