Old 12-25-2005, 05:59 PM   #1
Isphius
Isphius's Avatar
Default supercharger on a supra
anyoen know of anyone thats supercharged a 7m motor? i think that would be a cool project loo...noone else has one of those. The vortech superchargers can produce quite a bit of boost....and then you dont need all the exhaust work and blow off valves etc associated with a turbo.
Old 12-25-2005, 08:13 PM   #2
Bullz_EyE
Bullz_EyE's Avatar
I perosonally have never seen a supercharged Supra. If you supercharge you will still need to upgrade your exhaust to get the most from that setup. A blow-off valve is still recommended with a supercharger and you might even have to upgrade the injectors as well. Adding a custom supercharger may seem simple but there is a lot involved in order to get the most from it as well as even getting it to run properly.
Old 12-25-2005, 11:29 PM   #3
j3pz
ive thought about boosting my NA this way. be pretty sweet i think. lil bump of power to a pretty powerful engine. would prob skip a ic to keep it simple, it is just a daily driver. ya just like a turbo, more air means more fuel so upgrading that wouldnt hurt any.
Old 12-26-2005, 05:58 AM   #4
GreenChevelleSS
GreenChevelleSS's Avatar
GreenChevelleSS is on a distinguished road
Doing a SC is the samething as doing a Turbo its just driven by the engine instead of the exhaust. If you are boosting and engine and shoving that air in there and cant get it out then where is it gonna go? I supercharged an Iroc and It has stock exhaust with flowmaster muffler and we were craming all that air in the engine and it wasnt coming out so it found somewhere else to go....the dipstick....blew it out with lots of oil.
1990 Toyota Supra Turbo 7M-GTE
1970 Chevrolet Chevelle SS 396
1996 Chevrolet Silverado Z71
www.cardomain.com/id/3115ultima
GreenChevelleSS is offline   Reply With Quote
Old 12-26-2005, 10:17 PM   #5
j3pz
cool turned the motor into a weapon, its like james bond or something
Old 12-30-2005, 07:04 PM   #6
Isphius
Isphius's Avatar
i meant like....4 or 5 psi of boost. i dont think they can make much more than that, not from what ive seen anyway. instead of running a turbo, even if that s 4 or 5 psi, you still need to do all the piping work and oil returns and such. supercharger is just a bolt on item for keeping it low like that. no new manifolds or anything. i have another question thou. how do all of your vaccum accesories work with any kind of boost? like power brakes and all that. i know you could just put them infront of the boost adder but i never see anything like that included in the kits...
Old 12-30-2005, 08:24 PM   #7
Bullz_EyE
Bullz_EyE's Avatar
Here are some replies I got from a Honda forum I visit when I inquired about effects of boost on vacuum lines. (Yes, I own a Civic too)
"The stock brake booster has a one-way valve in the line so it won't see any boost.
The fuel pressure regulator works fine for boost and continues it's 1:1 pressure rise.
Evap purge is only actuated at certain times which I assume is somewhere in vacuum and low throttle.
The map sensor also can work as long as the voltage output is limited to keep the ecu happy (like in the hack or using a missing link). It's usable to around 11psi. cruise control. i just know that it still works. It's weird when you fall asleep and the bov wakes you up at the top of a hill....i bet."
"The brake booster has a bit of a reservoir for vacuum. Ever notice when you remove the booster line it sucks air in for a few seconds."
"Yeah, it is designed as a saftey feature to give you one.. maybe two good pumps before your brake assits runs out. It is for "emergency" use if the motor dies while driving."
Old 12-31-2005, 06:30 AM   #8
Isphius
Isphius's Avatar
lol well that makes snese i guess. i knew it worked just didnt know why. my friend has a grand national and the intake looks like a regular v6 intake and everything. thats when that popped into my head. hes also running this car at almost 450 horsepower(12.5s 1/4 mile) and all his vaccum accesories still work.
Old 01-10-2006, 01:03 AM   #9
RedSupra87
RedSupra87 is on a distinguished road
Default Thats funny
Ha ha thats funny.Someone else here talked about this very same thing although I never seen it myself.I wonder . . .
RedSupra''87''
RedSupra87 is offline   Reply With Quote
Old 08-07-2006, 03:15 AM   #10
86 supra
86 supra is on a distinguished road
Cool
I have an 86.5 i was thinking about putting a centrifical supercharger for a mustang 5.0 on does anyone know if it might work ? I know that Ill have to go with bigger fuel injector and a walbro fuel pump not sure about anything else ? I have milled 25 thousands off my head and I already have headers
86 supra is offline   Reply With Quote
Supercharger for 1988 Supra f355969 Non-Generation Specific Questions 6 09-26-2005 03:11 PM
