Old 12-09-2005, 07:04 PM   #1
flight doc89
flight doc89 is on a distinguished road
Default Blow-off valves
what's the highest pressure you can safely run on a 7m-gte before you need to get a blow-off valve, and do they increase performance at all (sorry, im just dumb and don't know anything)
flight doc89 is offline   Reply With Quote
Old 12-09-2005, 08:46 PM   #2
sakara
sakara's Avatar
sakara is on a distinguished road
I believe u should get a BOV if u are running anything higher then stock boost... I'd get one anyway... nice sound and lets off the extra pressure... it's just a good thing to have all around
sakara is offline   Reply With Quote
Old 12-09-2005, 09:39 PM   #3
joel w
joel w's Avatar
there should be a stock bov installed with all turbos,, just its vented into your accordian hose to you dont hear the psssshhhhttt. but if you up the boost, id think about getting a bigger bov as the stock bov is small.
Old 12-10-2005, 02:12 AM   #4
sakara
sakara's Avatar
the ct26 didn't come with a stock bov... the 3rd gen 3sgte engine did have one stock though... but unless ur engine came stock with one then yea... and I've never heard of an american supra or celica comming stock with a bov
Old 12-10-2005, 12:40 PM   #5
the supra has a stock bov
Old 12-10-2005, 03:35 PM   #6
joel w
joel w's Avatar
well my 89 did, looks like this right here? http://cgi.ebay.com/ebaymotors/SUPRA...21277993QQrdZ1
if it builds boost, it must have some way of releasing pressure when you back off the gas or shift..
Old 12-10-2005, 07:31 PM   #7
Bullz_EyE
Bullz_EyE's Avatar
Ya, 7m-GTE's have a blow-off. Well really it's a bypass valve because it vents pressure back into the intake track as mentioned previously.
Old 12-10-2005, 10:26 PM   #8
RedSupra87
RedSupra87 is on a distinguished road
Just get the blow off valve and save yourself the worry of doing damage with the stock one.Yes there is a stock one but its small,ugly,and dont make that hissing air sound.Sounds great dont it?
RedSupra''87''
RedSupra87 is offline   Reply With Quote
Old 12-10-2005, 11:30 PM   #9
joel w
joel w's Avatar
it will if you vent it to the atmosphere instead of back into the accordian hose..
Old 12-11-2005, 06:27 AM   #10
sakara
sakara's Avatar
well then... guess ya do learn something new every day
Noisy Valves spudz29212MKIII MKIII Supra 5 01-22-2009 03:37 AM
Some good info on Blow off valves mkiiisupra MKIII Supra 2 01-11-2008 02:13 PM
Valves, Cams,& the works carfanatic89 MKIII Supra 6 06-06-2007 04:02 AM
Do the MK3's have blow off valves? XKeyLocX MKIII Supra 5 01-30-2006 07:06 PM
Blow Off valves? lildawg720 MKIV Supra 9 06-13-2005 08:40 PM
