Old 11-28-2005, 03:16 AM   #1
cobrakiller
cobrakiller is on a distinguished road
Default locker for rear diff.
I was wondering if anybody knew of a place to buy lockers for the rear, im sick of my posi being a one tire fire...
1990 turbo supra, 3 inch exhaust, 10 psi.
1989 N\A body with turbo motor, 3 inch exhaust, 25 psi
cobrakiller is offline   Reply With Quote
Old 11-28-2005, 05:00 AM   #2
skunk
skunk's Avatar
hmmm I didnt know they made mk3 with out limited slip i can burn out my turbo 87 all day long and leave two rubber marks on the road. if yours is not limited slip maybe its possable to swap a rear differential from a supra that does have it???
Old 11-28-2005, 05:45 PM   #3
j3pz
ive heard of welding the gears together that way they cant slip
Old 11-28-2005, 09:41 PM   #4
just look in your local paper and see if someone is parting a supra out... what year is yours?.. they came with 3.7 and 3.9 in north america i believe... try the for sale/wanted section and see if anyone has one
Old 11-29-2005, 03:27 AM   #5
Wink
Never do this unless you are only on a drag strip, or dirt. Think about it. Why is the diff there?? so you can go around corners !!!
Old 11-29-2005, 03:50 AM   #6
cobrakiller
Default rears
i have 4 supras, 3 turbo and one n/a. two of the turbos are wrecked, so i took a turbo motor out and put it in the n/a body. The n/a has 4.3 gears with a posi, the other good turbo is 3.73 with a posi, but it slips, is there anywhere i could get just a rebuild kit for the posi? I know one of the wrecked turbo's has 3.73's, im not sure about the other one...never checked it.
Old 11-29-2005, 02:25 PM   #7
rnoswal
rnoswal's Avatar
The posi is supposed to slip so you can corner without ruining your tires. Make sure you have good lubricant in the rear end. I am not sure about this part, but I had a Jag that had limited slip and when the rear tires were up and you spun them they would both turn the same direction. I think the Supra's are that way too. If they spin opposite then there is no working posi or limited slip rear end, but I could be wrong about that. All I know is that after 190,000 miles, mine is still working and it does get used a few times.
Russ
Old 12-01-2005, 05:09 AM   #8
Jebus
Jebus's Avatar
Jebus is on a distinguished road
I had a friend try a trick on me telling me he had just got an MIG locker in his Corolla. MIG??? I hadnt heard of it but sounded right. Of course MIG as in MIG weld, a backyard weld job. lol. Try it on someone. I believed him as his Corolla had a VN v6 in it, and needed a locker.
For a Supra, you'd be crazy to put a locked set up in it unless all you do is race and dragstrip. The LSD is good.
If only my Supra had a Novarossi!
Jebus is offline   Reply With Quote
Old 12-01-2005, 01:56 PM   #9
rnoswal
rnoswal's Avatar
We use welded up rear diffs in our dirt track cars, but we have to use a staggered set of tires to get it to roll through the corners easier, but the compromise is that is also has to go straight too. Try pushing a car with the rear welded up! It is almost impossible, especially trying to turn it and push at the same time. For drifting and driving in the mud all the time it is worth welding. Street driving, no way!
Russ
Old 12-01-2005, 02:35 PM   #10
reep
reep is on a distinguished road
Default thats weird
mines a 86 and its limited slip
reep is offline   Reply With Quote
Non Turbo diff vs Turbo diff. abhattan MKIII Supra 0 04-18-2007 11:20 PM
Help..Diff Cont Indicator On (off) / No Speedo Malachiman MKIV Supra 8 03-13-2007 09:25 PM
Rear Diff? supraman121 MKIII Supra 4 11-19-2006 06:47 AM
open end diff. sucks!! 88Supraboy MKIII Supra 2 11-09-2005 08:16 AM
