Old 11-06-2005, 06:23 PM   #11
toyota_guru
toyota_guru's Avatar
toyota_guru is on a distinguished road
Originally Posted by joel williams
im not really pissed, now! i just didnt like when you said it was not even worth mentioning it here. if me spending coin on useless items helps someone else to save then its totally worth mentioning it whether im right or wrong.. and i did all the work myself. porting and polishing and so im only into it the cost of my time. as for the dual actuator it was 100 but allows me to adjust boost in the cab without a bleeder valve. yes you do make sense i do thank you for your info. i thought about getting a header, but ive heard that they crack to easy and that the gains where minimal without a larger downpipe. so like i said i got to start somewhere... what kind and where did you get yours? are you in the www.7mpower.com top 10? you should be with that hp
My manifold is an off brand from ssautochrome.com, it holds a t/4 or larger turbo and has a 4" wg flange, ss and ported and polished. with the support tabs welded in this thing and the flange size, i never had a problem with cracking, ive used this manifold on my first 2 high hp 7m's. I've never heard of 7mpower.com, i recently started going on line to see if there are any updated parts or software for this engine, im trying for 800hp reliably for racing, its gotta live. up till now, i used my dealership and track connections for my parts and info. the first two, the cars were totalled at the track, so im building my third with a few changes. my car is not what you call street leagal, i mean, i can drive it on the street if only i know where all the cops are at that time, i race it at Mid Ohio sports track against vetts, porche's, beemers, so its not as nice looking as the ones on 7mpower. cant seem to keep them rookie drivers from hitting me. You are right about needing a larger dp with a new manifold, but, you were gonna get one anyway. the header style manifold really cuts the turbo lag bigtime, so even with 8psi, it feels like 14psi instantaniously.
Not even close to stock!
toyota_guru is offline   Reply With Quote
Old 11-06-2005, 06:39 PM   #12
joel w
joel w's Avatar
ya im not going for massive power as of yet, the block is still stock so i dont want to exceed 400hp anytime soon and break it... and i want to keep this ct-26 for now and im not sure ive seen a header that uses the ct-26?
with your numbers, it sounds like you may have one of the fastest mk3's out there. certainly higher than any one at 7mpower although i have heard someone hit 800hp in vegas supra meet in a mk3 this year, but not sure who it was. thanks for the info... impressive...
Old 11-07-2005, 07:32 PM   #13
SupraMan1784
with that amount of power toyota guru should be number 1 on that list, correct if im wrong, also as long as you have the dyno pull to prove you have that power you're on that list, but you both are pretty much right... but in two different aspects, guru is right in the racing aspect...where you want to make as much power possible under a budget but pretty much enough power for the track...an off-road vehicle in this sense, as for joel, he's out making a street machine and not interested in pounding at the track at the moment, though i would have to admit...if i were joel's position i would have done the same thing as he did, because to me it makes the most sense for streetability with teh stock turbine and teh stock block, but of course i got rid of all that decision making when i swapped in a 1jz
Now: Saving for an MKIV
Broken Rides:
Old 11-07-2005, 10:44 PM   #14
joel w
joel w's Avatar
Default whew.
thank you supraman1784 , i may not have made that clear to the guru that i am making a street ripper and not a track racer. no plans for the track, autocross possably but the new things racing locally are the 125cc shifter karts and they look like alot of fun...
Old 11-08-2005, 05:56 AM   #15
Bullz_EyE
Bullz_EyE's Avatar
Just curious, what's your current elbo and downpipe?
Old 11-08-2005, 06:07 AM   #16
joel w
joel w's Avatar
im now running with a stock 90 ell that i ported out removed mass material , and the factory cats have been gutted and sleeved with 2.5" then all cat back is 2.5 mandrel with 3" flowmaster 2 chamber muffler its throughty
Old 11-08-2005, 07:20 AM   #17
1988gte
how does the flowmaster sound? any clips? i have been wanting a new muffler
Old 11-08-2005, 02:52 PM   #18
SupraMan1784
joel, isnt the flowmaster 3'' the one that sounds deep? like kind of a muscle car kind of tone? cause im lookin to switch out of my apexi n1...since everyone has one...i got a buyer anyways...im thinkin i might go hks carbon fiber....i heard that and i like the sound of htat....or the greddy evo
Broken Rides:
Old 11-08-2005, 03:28 PM   #19
joel w
joel w's Avatar
yeah it does remind me of of my old v8 days a bit, its got a nice rumble to it under throttle. but idles quiet...
my buddy bought it for his 4oo hp 86 dodge shelby charger 2.2l and it was too loud for his rig so he gave it to me. so it may be too loud for my new 3" pipes. ill take a vid if i can figure out how to post it....my cam takes avi's??
Old 11-08-2005, 06:05 PM   #20
SupraMan1784
yea cause teh n1 is kind of annoying now hahaha i got some dude in south jersey thats gonna buy it off me, i want something with a smoother sound
Broken Rides:
Something big is coming to northern Kentucky rebstew Off Topic Forum 1 07-17-2008 08:17 PM
Why is this smoke coming from the turbo? Turbotuner2.3 MKIII Supra 3 11-12-2007 03:30 PM
noise coming from rear of car? merryprankster MKIII Supra 2 06-21-2007 02:52 AM
Lights not coming up OfnaRcR MKIII Supra 8 02-04-2007 10:47 PM
Supra Girl Im Coming ozsupra Off Topic Forum 22 09-23-2004 03:43 AM
