Old 03-25-2026, 03:43 AM   #1
depami
Default Camshaft Needed
Need exhaust cam for 86.5 NA. Anyone know where I can get one?
Denny
82 5 sp 928 - Guards Red
92 FlightCraft 18 XLT
94 1200 Sportster
01 F150
depami is online now   Reply With Quote
Old 03-31-2026, 02:35 PM   #2
Bru
Bone Stock w Upgrades ;-)
Bru's Avatar
Also try the other forum. https://www.supraforums.com/forums/m...986-5-1992.13/
It's normal to have some scoring on the journals due to the soft metal. As long as the lobes and journals measure to spec, it should be serviceable.
http://www.cygnusx1.net/Supra/Librar...aspx?S=EM&P=48
Old 03-31-2026, 09:18 PM   #3
depami
Thanks, I don't have scoring but the distributor drive gear is trashed.
Denny
94 1200 Sportster
01 F150
Old 04-01-2026, 12:27 PM   #4
depami
Here's what happened:
After complete rebuilt, it wouldn't start.
Determined ignition timing was off and figured distributor was one tooth off.
Simple right, pull it out and put it back turned one tooth.
Well, the distributor wouldn't come out.
In trying to get distributor out, both distributor and cam gears got damaged.
It appears that distributor tail shaft galled in its' pocket in the head and held it in.
Why would that happen?
Did it not get assembly lube before installation and all the no start cranking was enough to gall it?
Is that pocket supposed to be lubed by an oil passage that got blocked?
I can't really see into it but the front of the head would suggest it might be fed by an oil passage.
I cannot blow air through it so either there is no passage or it is blocked.
I prefer not to pull the head if I don't have to because I'll need to buy another $200 MLS gasket.
First image is tail shaft pocket and second image is possible oil passage.
Anyone know if that pocket is supposed to be fed oil?
Thanks.
ID:	5083   Click image for larger version
Denny
94 1200 Sportster
01 F150
Old 04-02-2026, 12:54 AM   #5
Bru
Bru's Avatar
That's a pretty strange occurrence. I would expect the oil slopping around in there would lubricate it. If you have a borescope camera, you could take a peek in the socket. I would test fit the next distributor with the camshaft out to see how it's fitting. Grab the gear and move it up, down, left, right, to see if there is excessive play in the socket or distributor shaft. Here is a schematic of the oiling system from the online manual.
http://www.cygnusx1.net/Supra/Librar....aspx?S=LU&P=2
After you get the replacement camshaft installed, insert the distributor by the manual method. It should slide in or out without binding. Aim for the center of the bolt slot while inserting with the alignments set per the method.
http://www.cygnusx1.net/Supra/Librar...aspx?S=IG&P=17
Old 04-02-2026, 02:41 AM   #6
depami
Thank you very much.
That is an interesting oiling diagram that I have never seen before. And by the looks of it, that pocket doesn't have a feed and must just be splash oiled.
I looked in the pocket with a bore scope and can't see an oil passage but there was some galling. I was able to hone in clean and a 10mm rod fits nicely but my replacement distributor has a bent shaft (see images).
I found another distributor and cam shaft 2 hours away and plan to go check them out in the next couple days.
ID:	5085   Click image for larger version
ID:	5086   Click image for larger version
ID:	5087   Click image for larger version
Denny
94 1200 Sportster
01 F150
Old 04-02-2026, 02:49 PM   #7
Bru
Bru's Avatar
It appears that there are differences between the early 86.5 to 88 and the later 89 to 92 distributors. Here are some reference photos.
86.5 to 88
http://japan-parts.eu/toyota/us/1987...tributor#19100
89 to 92
http://japan-parts.eu/toyota/us/1989...tributor#19100
I'm not sure if there are any differences in the head they were meant to go into.
Old 04-02-2026, 02:55 PM   #8
depami
Thanks.
I noticed there are different styles. For sure the connector and rotor and who knows what else.
Denny
94 1200 Sportster
01 F150
It sounded like I needed new brakes.. Texican MKIII Supra 6 07-27-2011 09:48 PM
camshaft sensor toyota4life198031 MKIII Supra 6 12-05-2007 03:46 PM
Advice needed. Newbie looking to do a restoration right finaltable MKIII Supra 6 03-02-2007 02:57 AM
replaceing camshaft sevenmgte MKIII Supra 2 04-24-2006 03:54 AM
Looking for a camshaft upgrade Nato99 MKIII Supra 3 04-16-2006 05:33 PM
