Thread: Camshaft Needed
Old 04-02-2026, 02:41 AM   #6
depami
Thank you very much.
That is an interesting oiling diagram that I have never seen before. And by the looks of it, that pocket doesn't have a feed and must just be splash oiled.
I looked in the pocket with a bore scope and can't see an oil passage but there was some galling. I was able to hone in clean and a 10mm rod fits nicely but my replacement distributor has a bent shaft (see images).
I found another distributor and cam shaft 2 hours away and plan to go check them out in the next couple days.
ID:	5085   Click image for larger version
ID:	5086   Click image for larger version
ID:	5087   Click image for larger version
Denny
82 5 sp 928 - Guards Red
92 FlightCraft 18 XLT
94 1200 Sportster
01 F150
