#7 |
agreed with the above mentioned. but also try to retard your timing back a bit, your too far advanced possably, That 12 degrees you mentioned is that with the diagnostic timing jumper installed? set it to 10 degrees with the jumper installed, you may want to pull your upper timing belt cover and double check that the cam marks are in the corect position when its TDC on #1 and the timing marks at 0
Thread Tools | |
Display Modes | |
Citric Acid? To clean Catalytic Converters? For real? | ravenmaster | Non-Generation Specific Questions | 11 | 02-13-2018 06:23 AM |
HELP PLEASE | Nick0887 | Non-Generation Specific Questions | 4 | 02-28-2009 07:26 AM |
diesel tuning for supras....look now | corsamaan | MKIII Supra | 2 | 09-05-2007 05:25 PM |
Supra is dead.... | KNYFE | MKIII Supra | 23 | 11-21-2006 04:10 AM |
Engine Rattle .... Help! :) | roscoa1 | MKIII Supra | 14 | 05-18-2005 02:13 PM |
