#1 |
So the story started when I decided to rebuld my 7mge after previous owner and make engine bay cleaner. Took off all cooling hoses, throttle, intake and exhaust manifolds, then took off head, cleaned it, replaced valve stem seals, put new gasket, then built everything back.
Important to notice, EGR is bypassed (including vacuum lines change) as far as I can see. Connected all the plugs, connected ECU, put timing belt(using manual, following all steps), set distributor (again following manual, so the timing should be fine). Basically put everything(except cooling) the way it was before I took it apart. Buuut, when I try to start it cranks, revvs once and stalls immediately. What I checked:
Still no success, is holds a little using accelerator(opening the throttle) manually, but does very weird screech noise. Another thing I noticed is that I can't read diagnostic codes anymore(it was possible before rebuild). I jumpered T and E1 in diagnostic box and nothing. No check engine light at all, it's just off. Only alarm and "doors open" lights are on. I disconnected the dash and checked if the problem is in the bulb... Nope, there is just no signal to it at all(used multimeter). Rechecked all grounds again, nothing much, didn't find anything missing or displaced. Honestly it starts to piss me off... Spent a week on it already, no success at all... By the way, today tried to put a little gas directly inside the intake manifold, sound was a little louder but nothing changed. Would really appreciate the help guys as I have absolutely no clue anymore... If needed I can attach any photos and put videos. Last edited by wuder; 06-10-2022 at 05:37 AM. Reason: wrong date |
#2 |
Please anybody
#3 |
Bone Stock w Upgrades ;-)
Here is a link to the online manual. You say you have a GE so it starts there.
Ignition timing: http://cygnusx1.net/Supra/Library/TS...aspx?S=IG&P=17 Camshaft timing: http://cygnusx1.net/Supra/Library/TS...aspx?S=EM&P=29 Make sure the airflow meter is plugged in and that the bundle of ground wires on the intake side under the intake manifold is tightened down. I'm assuming you checked the valve clearance of each valve to be within specification. Valve clearance: http://cygnusx1.net/Supra/Library/TS....aspx?S=EM&P=8 Here's a link to another Supra website that may be of help to you. https://www.supraforums.com/forums/m...986-5-1992.13/ Last edited by Bru; 06-30-2022 at 06:18 PM. |
#4 |
I am a retired 36 year Toyota Master Tech, I did like you and worked at a dealership for 10 years and then opened my 1 man show Toyota repair service and ran it 26 years till I retired.
192.168.100.1 192.168.1.1 Last edited by dshaui; 10-02-2023 at 07:16 AM. |
| Tags |
| 7mge, check engine, ecu, stalling |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Diagnostic wont make my antilock light blink | SURFERDAVE | MKIII Supra | 3 | 07-24-2016 03:11 PM |
| MA70 Tail light Bulb Holders | juddruppert | Parts Wanted | 0 | 07-10-2014 02:30 PM |
| check engine light, no codes | CallieFornia | MKIII Supra | 1 | 10-26-2009 01:40 AM |
| Air Bag Fault Codes: 14 Squib Malf open & 22. Warning light, Please Help!! | Jap Imports | MKIV Supra | 3 | 06-07-2006 03:59 AM |
| diagnostic codes | Alberto O. | MKIII Supra | 5 | 07-29-2005 12:50 PM |
