#1 |
Anyone know where this goes?
I took it off ten years ago and don't remember. At the time I was dealing with heater hose but can't figure out where it would bolt on. 86.5 NA manual. Thanks
Denny 82 5 sp 928 - Guards Red 86.5 auto 928 - Meteor Metalic - No Rub Strips 86.5 5 sp Supra SR/SS - Amethyst 92 FlightCraft 18 XLT 94 1200 Sportster 01 F150 |
#2 |
Bone Stock w Upgrades ;-)
It's like you said: heater hose area. I believe I've seen this at the very back of the head in the valley holding a hose. The hex retaining plug for the valley plate, behind spark plug number 6, is threaded in the center. I have a GTE so I can't be more specific other than remembering photos I've seen or parts yard flashbacks.
#3 | |
Thank you! That's exactly where it goes. Now I remember, replaced that hose with non-formed and the bracket doesn't fit. Should probably get the correct hose. On a side note: Fixed the EGR cooler cover to block leak with JB Weld and it has held so far for a couple hundred miles.
| Thread | Thread Starter | Forum | Replies | Last Post |
| Housing clamp for supra turbo? | bombinuass | MKIII Supra | 1 | 03-10-2010 03:18 AM |
| Mystery Wire? | Cyto | MKIII Supra | 6 | 10-19-2009 06:21 PM |
| No spark mystery on 7mgte | jcgrant4 | MKIII Supra | 9 | 08-19-2009 06:21 PM |
| what a loose battery ground clamp does | ghost88 | Non-Generation Specific Questions | 0 | 02-25-2009 04:42 AM |
| ignition mystery (what a surprise) | mattfurlani | MKIII Supra | 0 | 09-27-2007 02:09 PM |
