Old 07-25-2018, 05:27 AM   #1
jake775
jake775 is on a distinguished road
Default help identifying this part
what is this and what dose it do exactly? im hearing what sounds like air leaking from this or something near it cant find the part in my haynes book or on any part layouts i can find online http://photos.google.com/share/AF1Qi...tlUlp6OHJWSXFB
jake775 is offline   Reply With Quote
Old 08-04-2018, 09:18 PM   #2
Bru
Bone Stock w Upgrades ;-)
Bru's Avatar
It's the vacuum servo that opens and closes the hot water to the heater core. When no vacuum is applied it's closed. If the electric actuated solenoid still works and you press The climate control buttons for temperature higher than ambient, it should open. You can use a hand vacuum pump to test the diaphragm / valve. I have already replaced this once because the electric solenoid became sticky and wouldn't open even with a vacuum applied by the vehicle. I would check for leaks and vacuum and also that the solenoid works by carefully applying 12V to the plug disconnected. It could be stuck open also.
Tags
7mgte, need help
Need help identifying a part and thought on a miss at idle --WAS: newbie milc80 MKIII Supra 8 06-28-2010 12:53 PM
What do you call this part? Part Number? suprajim MKIII Supra 8 02-27-2010 12:57 AM
My 88 Part List Grandavi MKIII Supra 18 05-24-2009 11:04 PM
New here and I need some help identifying a part bmc52387 MKIII Supra 3 03-21-2008 05:24 PM
