Old 07-23-2016, 01:16 PM   #1
87boosted
87boosted is on a distinguished road
Default 7mgte overheating problem
I recently bought a 87 supra with the 7mgte. ive been driving the car for a little over a month with no problems. About a week ago it started running warm when its sitting. As long as the car is moving the temp stays normal but when you stop it starts climbing. Ive read a lot about the dreaded blown head gasket problem and I just wanted some advice before I try to replace it. I'm not sure if the head gasket is the problem, ive checked the oil and it doesn't look milky. I have also replaced the radiator and when I drained the old coolant it was pretty clean. was just wondering if it may be something other than the headgasket. Any advice would be greatly appreciated! thanks!
87boosted is offline   Reply With Quote
Tags
7mgte, mark3 help, mkiii, overheating
idle problem 7mgte im lost dwthomas42 MKIII Supra 3 09-13-2012 04:14 AM
1992 7mgte overheating and blowing head gasket drewmiller5007 MKIII Supra 5 07-04-2010 09:24 PM
need help with 7mgte idle problem MAG.net MKIII Supra 4 09-06-2007 06:10 AM
'92 Supra 7MGTE overheating - need help pls. liona MKIII Supra 7 05-19-2006 04:06 PM
overheating problem on 1990 supra turbo suprasux MKIII Supra 16 06-13-2005 10:39 PM
