Old 02-27-2015, 06:30 PM   #1
Idle problems
Idle problems is on a distinguished road
Default Idle problems
Will go out to start the car and it will go up like it wants to run then immediately drop below 500 rpm killing the engine, Restarting car with gas pressed a little will be a bump a little and smooth out, in order to drive you cant let idle drop to low, upon stoping completely and taking off its studders from 1000 rpm to 1200rpm, at 1200 rpms it wont stutter after stoping (it wont stay above 700 unless gas is pressed ) NA 91 no engine light and was working fine the other day, It seems to change weekly from really high idle (40mph) to a fluxuating out of gear idle to a very low idle. also normal idle days after going 80+ for extended period upon reaching a exit ramp the idle will drop and car will die and you have to hold gas abit down to go
Any ideas?
Idle problems is offline   Reply With Quote
88 Supra N/A refuses to idle btwilson86 MKIII Supra 5 05-23-2014 10:16 PM
idle problems 88 supra turbo MKIII Supra 14 03-13-2010 03:43 AM
1990 supra n/a idle problems Scraperondubz MKIII Supra 6 03-06-2010 06:45 PM
Idle Problems kidsusukigsxr MKIII Supra 4 11-12-2008 05:17 AM
Having some idle problems...please help, details inside noredline MKIII Supra 6 09-18-2006 11:38 AM
