Old 02-22-2015, 04:30 AM   #1
zonian91
zonian91 is on a distinguished road
Default Oil leak
My son just bought his 1st car today. A beautiful 1987 Supra (non turbo). The car drove amazingly great, but after we got done eating dinner we noticed an oil leak. We checked the oil before leaving and the level was full. Any info on common oil leak problems with this model?
zonian91 is offline   Reply With Quote
Old 02-22-2015, 05:04 AM   #2
zonian91
A little help please!
Old 02-22-2015, 03:46 PM   #3
btwilson86
Super Moderator
btwilson86's Avatar
I'd check first to see if you can narrow down what part of the engine you see the leaking at. If I couldn't determine that, then I look at the oil drain plug and oil filter, I've found those loose on a couple cars I've had. If that looks okay, then there are a couple common oil leaks on these Supras. Check on the exhaust side of the engine just below the distributor. Lots of oil there? Likely a bad o-ring around the distributor shaft. Remove distributor, replace o-ring, reinstall distributor, and reset ignition timing. Another common oil leak is the no. 3 cylinder head cover. This is the piece that runs the length of the engine between the valve covers, that the spark plug wires clip into. This cover doubles as a gasket for 4 oil passages across the cylinder head. When these leak, which they almost always do, you usually find lots of oil on your spark plug wires, and it can get bad enough to cause misfires if left unchecked. You likely won't see the oil until you pull a spark plug boot out and fling oil everywhere. This piece is fairly straightforward to replace after removing the throttle body, intake pipe, and spark plug wires. Remove it by removing the 4 oil plugs holding it in, they use a 14mm hex key or Allen wrench. If it was leaking, you should replace your spark plug wires and possibly spark plugs as well. Also, since you're already torn down this far, its not a bad idea to replace the valve cover gaskets as well, as they tend to leak a little oil with age.
Old 02-22-2015, 07:29 PM   #4
zonian91
Thanks a lot for responding and the advise. I'll check that out ASAP.
Old 02-23-2015, 03:09 AM   #5
zonian91
Looks like you were right. There is a lot of oil built up underneath the distributor and there was also a lot of oil around the spark plug wires on the head. I sprayed some purple power on it to clean it off before tearing it down, but now the car is idling rough! It was running perfect before?
Old 02-23-2015, 01:53 PM   #6
btwilson86
Super Moderator
btwilson86's Avatar
If the oil is around the spark plug wires, it seeps into the wire making a poor connection to the spark plug causing the spark to short at the cylinder head and not travel to the plug, resulting in misfires and rough running. I'm not sure how a degreaser could cause a rough idle, unless a lot of it collected in one spot and is basically doing the same thing the oil was
Old 02-23-2015, 02:02 PM   #7
zonian91
What do I clean the wires with? Is electrical wiring spray good enough? Thanks again for your help.
Old 02-23-2015, 06:45 PM   #8
btwilson86
Super Moderator
btwilson86's Avatar
I've never had any luck cleaning them off to try and get rid of the oil, to be honest every time it reached that point I ultimately replaced the wires because the oil soaked into the rubber and ruined it anyway. On my old '88 non turbo, I deleted the center gasket so I could see in around the plug wires, and just bought a set of ACCEL wires for a V8 and made my own. I'll see if I can find a pic, if so I'll share it on here. I thought it turned out nicely
Old 02-25-2015, 11:04 PM   #9
CoosSupra82
CoosSupra82 is on a distinguished road
Is a Toyota dealer the only place you can buy the #3 cylinder cover? I have been looking online everywhere and can not find one.
CoosSupra82 is offline   Reply With Quote
Old 02-25-2015, 11:15 PM   #10
zonian91
Yes, there is, but why do you need that? The car should not be leaking oil anywhere. I took it to a shop today and going to go ahead and replace crank seals, distributor oil seal, timing belt and water pump. Better safe than sorry. Those motors cost too much.
Rear Head to Block Oil Leak Fix (no teardown) Bru MKIII Supra 0 10-31-2014 04:41 AM
Hard to find A/C Leak fox74 Non-Generation Specific Questions 0 08-18-2014 11:13 PM
Heater Union (Coolant Leak) slader99 MKIII Supra 11 12-28-2009 12:29 AM
Coolent hose leak. probably heater core Green7mgte MKIII Supra 7 11-26-2009 04:43 PM
Oil Leak Question kidsusukigsxr Non-Generation Specific Questions 2 06-26-2007 03:17 PM
