Old 09-17-2014, 08:15 PM   #1
interested!
Question Low oil pressure under load
Hi ! , Is there any way you can connect up a pure pressure readout pressure gauge to check against your electric one ? .
Old 09-17-2014, 09:30 PM   #2
White Slicktop 87
White Slicktop 87 is on a distinguished road
It would be no point as the oem electric gauge doesnt work. Thats why i have the aftermarket one
White Slicktop 87 is offline   Reply With Quote
Old 09-18-2014, 05:14 AM   #3
btwilson86
Super Moderator
btwilson86's Avatar
Its not uncommon for the OEM guage to quit working; all it takes is one brief moment of the signal wire shorting out to kill it.
You say you have an aftermarket gauge installed now? Is this a mechanical gauge (oil filled line running directly to the gauge in your car) or an electric gauge (sending unit like OEM with wire running to the gauge)?
Electronic sending units fail, sometimes fairly often depending on quality of parts, and this can be the source of your strange readings.
I would first verify your oil level is correct, then temporarily hook up a mechanical oil pressure gauge to verify your SunPro gauge is reading accurately.
Old 09-18-2014, 12:54 PM   #4
White Slicktop 87
My sunpro guage is a mechanical one
Tags
7mge, low oil pressure, mk3, mk3 supra, under load
Power Steering Pressure Hose Step by Step SilverMK3 MKIII FAQ 1 02-20-2011 09:38 PM
7MGE oil pressure problems I h8 Hondas MKIII Supra 18 07-18-2010 06:27 PM
Oil Pressure? supraguy MKIII Supra 3 09-16-2009 08:35 PM
7MGE oil pressure Arne (Denmark) MKIII Supra 14 07-31-2009 10:07 PM
Fuel pump relay and pressure. carfanatic89 MKIII Supra 8 05-01-2008 06:39 PM
