Old 04-12-2014, 12:43 AM   #4
The bypass channel is the main difference. Restrict that and you should be closer to safe. I wouldn't run at much more than idle while the engine is cold or the system is in open loop until either fueling or airflow is properly accounted for though.
87 Turbo knock sensor issue supraman7 MKIII Supra 5 03-05-2010 07:44 PM
A340E Speed Sensor GettaRobo MKIII Supra 0 08-06-2009 06:59 PM
TPS Sensor and Auto Trans btwilson86 MKIII Supra 5 02-12-2008 07:31 PM
Knock sensor for an N/A. rnoswal MKIII Supra 2 11-16-2005 05:12 PM
