Old 10-23-2013, 11:17 PM   #1
IchibanEye
IchibanEye's Avatar
IchibanEye is on a distinguished road
Default ??Lowered on spings/rear camber??
Hello my car is lowered on springs and my left rear camber is not tracking at 0. It is leaning in, I believe this to be negative camber if memory serves me correctly.
My right rear is fine but not the left. I have heard the factory control arms are pretty apt to flex/bend. Is this true? Is there a rear camber kit that I can buy to correct this problem? What about better/adjustable control arms to fix the camber issue? Please help me so I will not be burning through rear tires.
thanks.
The Steez Stomper! Btw my sister wants her skinny jeans back you fool
IchibanEye is offline   Reply With Quote
Old 10-23-2013, 11:55 PM   #2
You're supposed to have some negative camber. Measure it and see if it's actually off or if the other side is off.... possibly both are. The control arms on the MKIII are pretty robust. With some of the higher end builds they can use replacement but generally the only remotely common problem is the tabs for the sway bar end links rusting and breaking off. If the bar is bent someone more likely kissed a curb. It's also quite possible that the bushings are gone to the point that there a good amount of slop in the suspension geometry. If everything else in the suspension is in good shape the stock hardware will accommodate a significant amount drop and still adjust within spec.
Old 10-24-2013, 12:42 AM   #3
IchibanEye
IchibanEye's Avatar
@cre I inspected the arms/bars and all is fine. However I will have to inspect the bushings much closer.
I talked to the previous owner and assumed he had redone all of the rear suspension components and bushings when he completely re-did/replaced all of the front suspension components, I was wrong.
I will eventually put all new stuff in the rear but do not want to drop the coin on all of the at the moment. I will just try to fix the one issue for now.
It just baffles me as to how far the difference is between the two rear wheels. Based on what you said I am guessing the bushings are mush. Thanks for the heads up and ill keep you posted.
However on other lowered cars I have owned I was able to have a neutral stance when it came to wheel alignment/toe/camber and the such. Sounds like I can not get to factory specs with my lowered Supra however.
Thank you sir.
Max stock camber? edfishjr MKIII Supra 0 10-30-2010 03:02 AM
U-Weld Rear Camber Kit CanadianBak'inSupra MKII Supra 2 08-04-2010 03:53 PM
negative camber BlkSupra84 Non-Generation Specific Questions 4 10-30-2007 01:48 AM
rear camber problem suprafast MKIII Supra 4 12-29-2004 09:49 PM
