Old 10-15-2005, 11:49 PM   #11
hangsupra
i not sure bout the mk3 but my mk2. when it happen like that on me... i check it... n the proble i found is the radiater cap... i replace with the new one n it works fine..... oh by the way. check on your radiater cap.. second check on the radiater to see if there is any leak... third... check on your water pump... sometime it does that too... one more thing... if your car is a turbo then sometime the turbo is causing too... double check on it... start the car n look at the back see if there is any smoke... coming out from the exhaust... that what happen to my mk2 turbo tho... n i rebuild my turbo n after i rebuild my turbo its fine to... so check on that to... n double check on all your water hosing to see if there is any water leak alright. hope this work. let mek now how you get to work alright.
Old 10-16-2005, 07:43 AM   #12
rnoswal
rnoswal's Avatar
Mine too. Bad freeze plugs and corroded head and gasket. There are differences in water pumps too. Some don't circulate the water very well at all and if there is any air in the system, it expands and blows out the overflow especially if you have a bad radiator cap. What Suprra_girl said was very true. You might want to offer her some of that Caviar you mentioned in your first posting though because she may now a better way to keep it out of your teeth, and if you are off a tooth, then that could mean everything.
Russ
Just my opinion of course though.............
prepping block for headgasket question dannydavi MKIII Supra 1 12-06-2008 07:44 AM
1JZ question for all you 1J guys supradaddy0803 MKIII Supra 1 05-23-2007 01:30 AM
Question... sakara Non-Generation Specific Questions 7 12-06-2005 09:26 PM
