Old 06-05-2013, 09:55 PM   #1
Sonyps307
Default Combo light switch going bad
Ok so my tail lights and rear side markers and maybe the License plate will not come on I checked the relay, taillight Failure sensor, bulbs and fuse. So I'm asking could the combo switch go bad to where only these lights don't work but all other lights still do work also my brake lights still work.
Old 06-05-2013, 11:10 PM   #2
All of the lights you are talking about are part of the TAIL circuit which has it's own fuse. The failure module is only suspect if the front markers and dash lighting is functional. The circuit does have it's own contacts in the combination switch. That's where I would start as well.
Old 06-06-2013, 06:55 AM   #3
Sonyps307
All lights work including front markers, headlights, fog lights, all gauges, turn signals, and brake lights when brake pedal is pressed. Only lights that don't work r the tails, rear markers and License plate lights. I did the Failure module bypass by jumping the wires and still only brake light work no tails still. I think it's the combo switch ill test it tomarrow. Thanks
my fog light switch suorajd MKIII Supra 1 03-22-2013 09:40 PM
??MYSTERY?? Plug near combo switch main plug Supra Saiyan MKIII Supra 8 01-03-2011 08:29 PM
Brake light switch... MK_matt MKIII Supra 6 12-12-2010 04:18 PM
Reverse Light Switch - The where and how georides MKIII Supra 1 09-12-2010 03:32 AM
Brake light switch and neutral safety switch problems jtown125 MKIII Supra 26 05-02-2010 04:22 PM
