Old 04-21-2013, 03:21 AM   #1
Busted Knuckles
Busted Knuckles's Avatar
Default Anyone still have the coolant hose part number diagram?
I've been chasing an intermittent coolant leak for the last month and a half. 3 weeks ago, I added a UV dye to the coolant, and it refused to leak until this morning. It is definitely a leaking water pump. The weep hole was glowing green under a UV lamp. So, I'll be replacing the water pump soon. I'd also like to replace all the rubber coolant hoses since I had two failures in the last year or so, and some of the remaining hoses are looking rough.
Someone at one time posted a diagram of the coolant hoses with part numbers for each one. I think it may have been purged with the thread cleaning, so I'm hoping someone has saved a copy? Thanks in advance. Mines an '88 N/A LHD.
Old 04-21-2013, 04:56 PM   #2
http://www.cygnusx1.net/Supra/Librar...spx?F=1603&P=1
http://www.cygnusx1.net/Supra/Librar...spx?F=8716&P=1
Coolant Hose Diagram IHateHacks MKIII Supra 11 07-02-2013 03:08 AM
Auto Supra Coolant hose pressure and return leak to oil pan and filter area? rjSupra MKIII Supra 45 01-18-2011 12:12 AM
Part number? Krem MKIII Supra 2 06-23-2010 02:26 AM
What do you call this part? Part Number? suprajim MKIII Supra 8 02-27-2010 12:57 AM
WTK Part numbers from engine number ravi4001 MKIV Supra 5 01-28-2010 12:34 AM
