Old 03-15-2013, 02:45 PM   #1
Paul11
Paul11 is on a distinguished road
Question 1989 Toyota Supra Turbo
Please help!
I absolutely know nothing about cars but to turn the key and drive; however, I brought my sons car into to the shop to have the head gasket repaired and now the car will not go more than 20mph. Initially when the mechanic said the car was finished my son went to pick it up and it would shut off at 30 mph, then the mechanic changed the mass airflow sensor and now the car will not go over 20mph. Fuel injectors were checked, plug wires, radiator was changed, any suggestions? Thank you, Angela
Paul11 is offline   Reply With Quote
Old 04-06-2013, 04:54 AM   #2
Sigh.... seems we may be having a database error. This goes in the MKIII section. The tire commentary belongs in MKII. Hopefully the error message goes away now and the threads go where they belong.
Old 04-06-2013, 05:05 AM   #3
Angela, it's been a good amount of time since this was posted, have you found the answer to your problems? In the MKIII FAQ section there is a thread on how to check and read diagnostic/error codes stored in the car's computer.
Old 04-06-2013, 12:24 PM   #4
MA70-3.0GT
MA70-3.0GT's Avatar
Angela? this thread's Paul11 isn't it?
Agreed, the diagnostic check needs to be done to see what codes are being shown up if any. (That said, the mechanic really should finish the job, if it won't do over 20mph it obviously isn't "done")
To be honest though I'd perhaps consider changing shops if he considers that to be fixed
If you can do the diagnostic check & report back the codes we'll have a stab at getting it purring... This link should show how to do the diag check http://www.cygnusx1.net/Supra/Librar...ection=FI&P=23
The "SST" is just a piece of wire/paperclip or similar to connect the Te1 and E1 pins in the diag socket by the way, no need to buy one!
1989 Toyota Supra Mark 3 Single Turbo GT Minymurf Show n Tell 2 05-02-2011 10:55 PM
What's the value of a 1989 Toyota Supra? MysticKnight MKIII Supra 14 02-13-2011 05:26 PM
1989 Toyota Supra turbo ccranor16 MKIII Supra 5 02-18-2010 02:33 AM
Toyota Supra -95 Non turbo upgrade! Supraboy_ MKIV Supra 3 01-08-2006 01:00 AM
1986.5 Toyota Supra Nppn Turbo- New Turbo Help ! DarkRaiderz MKIII Supra 6 12-27-2005 09:04 PM
