Old 04-03-2013, 12:24 PM   #1
MA70-3.0GT
MA70-3.0GT's Avatar
Oil burning could also be from the BHG & to be honest likely is just that if it didn't smoke before.
If it was smoking anyway, valve guides/stem seals usually cause a puff of smoke on startup & a little trail while decelerating from high revs on closed throttle, bores/rings (or turbo seals don't forget, puddles in your intercooler & 3000 pipe?) would be more likely to cause more constant smoke even when accelerating or running for a while.
Tags
1jzgte, 2jzgte, 7mgte, money, swap
Putting JDM engine in!!! :D dannydavi MKIII Supra 24 11-02-2009 06:30 AM
how fast should my engine use up its oil? sd88supra MKIII Supra 10 03-25-2006 03:21 AM
