Old 02-22-2013, 09:54 PM   #1
agui_mkIII
agui_mkIII is on a distinguished road
Default 89 toyota supra non turbo headlight troubles help please
I just got my first car, 1989 Toyota supra, and the headlightss constently stay on so i have to unhook my battery everytime I park it. Any help?
agui_mkIII is offline   Reply With Quote
Old 02-25-2013, 02:07 AM   #2
More often than not it's an issue with the switch.
Here's the body/chassis electrical section of the Toyota Service manual for the '91 Supra (most of it is the same from '89 through '93). http://www.cygnusx1.net/Supra/Librar....aspx?S=BE&P=1
Old 02-26-2013, 06:00 AM   #3
agui_mkIII
Awesome thanks i bought the relay fuse for the headlight and it wasnt that so this helps I appreciate it
Old 03-13-2013, 01:47 AM   #4
suorajd
suorajd is on a distinguished road
I have a 87 turbo with the same problem and i have been through the wiring twice and checked all the relays . Changed the light switch the rtr control box bypassed the theft system only thing i can figure out is the headlight relays is getting 12volts before it get to the switch i can't find it but instead of undoing ur batt .just take ur headlight relay out and that will cut ur headlights off every thing else will world as normal just remember to put it back in just for ur headlights urparking lights and brake lights will function fine without the headlight relay
suorajd is offline   Reply With Quote
Old 03-14-2013, 06:25 AM   #5
agui_mkIII
Yea thanks I started to do that once I got thw new relay but question my efi relay gets really hot n like is shorting or something because if i push it don't or sligjtly move it, it buzzes or clicks, something of that sort n since the headlight relay is near maybe my wiring is messed up somewhere? I mean this car has many loose plugs n such. But was just wondering if those two may br hand in hand
Old 03-15-2013, 04:20 AM   #6
The EFI normally gets hot on many cars including the MKIII... Most likely nothing's wrong there.
Old 03-15-2013, 06:07 PM   #7
agui_mkIII
well should it buzz and click when being touched? i recently ran into a problem with the car starting and dieng right after so i replaced the spark plugs thinking itd fix the problem but that didnt fix it. but i dont know if the TPS is connected right or if the EFI relay would play a roll in it not running properly.
Old 03-15-2013, 08:44 PM   #8
MA70-3.0GT
MA70-3.0GT's Avatar
Have you checked for codes? you'll know if the TPS is out of calibration then.
Clicking/buzzing relays can be either bad relay or loose/dirty connections, maybe you could pull it out & check that it's terminals are clean and the ones it pushes into are tight first...
Do the headlights still stay on with the switch on the steering column unplugged? And if so, what about with the fuse taken out?
1987 Toyota Supra 1JZ-GTE Twin Turbo Targa Top AZ AlexSchuSupra Buy/Sell Cars 1 01-31-2011 07:00 AM
Have you ever experienced someone SupraHead MKIII Supra 8 10-30-2010 04:06 AM
1989 toyota supra non turbo low oil pressure bayrat MKIII Supra 6 09-19-2010 05:33 PM
1997 toyota supra turbo chunner1 MKIV Supra 0 05-07-2010 05:27 AM
93 toyota Supra Twin Turbo Engin wont shut off fastandfurious93 MKIV Supra 5 09-08-2008 06:50 PM
