Old 12-29-2012, 03:57 PM   #1
907mge
907mge's Avatar
Default Whats LSD ratio came in what supra?
I was wondering what my 90 NA auto should have in it? I would like to put in an lsd but am a little unsure what is in it now for the open diff. Also I have a 3.9 and 4.3 any recommendations on the that?
Old 12-29-2012, 08:50 PM   #2
Sonyps307
My 89 na has the 4.3 LSD rear in it.
Old 12-30-2012, 12:06 AM   #3
All N/A's came with a 4.30:1 open or the optional 4.30:1 LSD.
'87 and '88 Turbo models came with a 3.91:1 LSD.
'89 through '92 Turbo models came with a 3.73:1 LSD.
There was an optional Torsen differential offered only on 1JZ models (JDM only) I can't remember the ratio.
Old 12-30-2012, 02:46 PM   #4
907mge
907mge's Avatar
Ok, thank you. Would there be any benefit to switching to a 3.9?
Old 12-30-2012, 10:52 PM   #5
Well, you'll see somewhat better highway cruising mileage but beyond that it depends largely on your driving style. Your city and aggressive driving mileage will most likely take a hit as your acceleration will be worse and you'll have to apply more throttle or you'll have to stand on the throttle longer to reach any given speed. If you're a laid back, 'I'll get there when I get there' sort of driver and you want a mild improvement in mileage then go for it. The mileage improvement isn't huge. The LSD is definitely worth having over the open diff in most cases but you might want to see if you can find a 4.30:1 LSD from another N/A first.
Your speedometer and odometer will be off unless you swap in the speedo drive gear from an auto equipped MKIII. The speedo drive gears from the W58, the R154 and the A340E are not interchangeable.
Old 12-31-2012, 02:54 AM   #6
907mge
907mge's Avatar
Yeah you confirmed what I was thinking. I do have a nice 4.3 that I think I will use then. Thanks
