Old 10-10-2005, 06:52 AM   #1
kewlcoconut
Unhappy Steering Noises
The other morning, I started up my car and it seemed fine. But then when I would go to turn the wheel to turn a corner or whatever, it seems like something to do with the steering is rubbing or something. It makes a weird noise when I turn the car either direction. This only happens when the car is cold. After a while, it goes away. But I never had this problem before. Sounds like it is rubbing, and I can feel some vibration underneath where when my feet are on the pedals.
Old 10-10-2005, 10:54 AM   #2
Probably the power steering rack. Not difficult to replace. Cost approx. $200 for reman.
Old 10-11-2005, 11:52 AM   #3
robbie
robbie is on a distinguished road
Thumbs up hey kewlcocunut
Hey just letting u kno before you go ripping steering racks outa beaten up mkiii's my friend had the same problem at parking speeds and hard cornering try checking your pwr steering belt n pulleys first i kno id rather spen $20 on a belt that replace tha whole thing...
robbie is offline   Reply With Quote
Old 10-11-2005, 12:51 PM   #4
miisterMK3
miisterMK3 is on a distinguished road
i got the same problem, but can't be stuffed to fix it......a little noise doesnt hurt right?
miisterMK3 is offline   Reply With Quote
Old 10-11-2005, 01:24 PM   #5
SupraMan1784
i was thinking the steering rack also...i had that problem...but check the belt and pulleys first..since mine were ok...i found that one of my joints was ripped...so i bought an aluminum one for about $225...its kind of a bitch to install though...but its do-able...would take you about 2.5 hrs if you know wut ur doing..a little longer but anyone can figure it out...must make sure you change the power steering fluid..and all the lines are tight...drain teh fluid...keep the cap open...start the car and turn the steering wheel all the way to one side then teh other...do it like 4 or 5 times... so the fluid gets back into the lines and you should be ok....i was an idiot...i dint check my lines i poured a bottle and it came out the bottom...and i was wondering why the steering still sucked...one of my lines wasnt tight...leaking like crazy
Now: Saving for an MKIV
Broken Rides:
Old 10-11-2005, 03:24 PM   #6
rnoswal
rnoswal's Avatar
I was just going to suggest checking your fluid, but you probably already did. Sometimes the bolts holding the rack in just fall out for some mysterious reason. Check the other stuff peole have mentioned and let us know.
Russ
Old 10-13-2005, 04:16 AM   #7
If you do the rack, get new line/fitting... gasket/washers from the dealer (3-4$) !!!!!!!
Old 10-14-2005, 01:14 AM   #8
Moonraker
Moonraker's Avatar
Moonraker is on a distinguished road
Default Check for fluid leaks 1st
Overnight try putting a clean piece of paper under the passenger side near boot and check it in the morning... if you find power steering fluid, it'll be the rack 9 times out of 10.
Moonraker is offline   Reply With Quote
Having Trouble Removing the Steering Wheel Chambers MKIII Supra 3 06-30-2008 01:03 AM
Steering problems drmmr15 MKIII Supra 17 03-08-2007 09:32 PM
Steering wheel off-centre colin172 MKIII Supra 3 10-06-2006 01:41 AM
Steering noises das MKIII Supra 8 12-07-2004 11:36 PM
