#1 |
![]() Toyota Racing Development Join Date: Apr 2007
Hatch seal, rear wiper seal and tail lamp seal are the three entry points to be checked and repaired. Not only do these commonly kill the TLFM but they also usually cause some of the hardest rust to repair on this car.
I wouldn't drill more than one or two weeps in the bottom of the housing... I'd worry more about keeping the water out to begin with. Place it in a zip lock bag with the mount at the bottom of the bag, then put the screw through the bag in that one spot. Leave the mouth of the bag (which is at the bottom) open and run the harness in through there. Remove any harness hangers which hold the harness too high as this gives water something to run along and follow into the TLFM.
If something breaks or you need to contact a member of the administration please post HERE. Unless it's a private or administration matter please post it on the forum. It benefits no one else if car related questions aren't posted for future users and takes away from the time I'm able to spend helping on the rest of the forum. If you're so inclined I'm always more than happy to accept tips via PayPal. ![]() Tip Jar ---> ![]() |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| MKIII Wilwood 12.9" Rear Brakes With Parking Brake | ARZ | Arizona Performance | 0 | 08-25-2010 06:34 PM |
| My brake lights are stuck on. wtf! | Isphius | MKIII Supra | 16 | 09-07-2009 08:48 PM |
| Maintenance brake and clutch master cylinder fluid | IHateHacks | MKIII Supra | 1 | 04-18-2007 07:15 PM |
| Wilwood MKIII Rear brake kit | ARZ | Arizona Performance | 0 | 03-16-2007 07:46 AM |
| 87 supra brake lights | ministrytrav | MKIII Supra | 4 | 11-23-2005 08:53 PM |
