Old 09-28-2012, 06:16 AM   #1
The thermostat is a thermostatic bypass. In a full flow oil cooling system all of the engine's oil flows through the circuit. Just like engine coolant you don't want the oil too cool just as much as you don't want it too hot. The thermostat closes and bypasses the oil cooler if the oil temp is low. I don't know if anyone makes a kit. It's really a pretty simple setup if you don't over think it.
7M-GE oil filter nipple P/N 90404-20173 Replaces the whole filter head assembly from the GTE.
Oil filter block adapter
Remote oil filter head
Oil Thermostat
Cooler
Hoses and fittings
Everything needs to be either 1/2"NPT or -10AN.
Old 12-21-2012, 12:00 AM   #2
Piggy808
Piggy808 is on a distinguished road
I know this is an old post but I thought I would slip some related questions in:
I didn't know there was a stock oil cooler??? In any case I installed a remote filter...and an aftermarket oil cooler on the same lines back...so I went to go see where this stock oil cooler looks like. Its mounted on the right side of the radiator right? Anyways, since it operates on bypass...i was wondering if there are any benefits to just deleting it and maybe even using it as a replacement for my stock powersteering cooler so i can get rid of that long wierd thing of a cooler those japanese guys engineered. Or should it not be deleted? I just see it as more places for possible leaks.
CRE, you cut the hard pipes and ran hoses to your aftermarket PS cooler...was it pushlock hoses? anything special about them? I was under the impression that the pressure would pop off any type of hose, so braided lines is a must, even on the PS system. (I read that thread that you linked)
1991 Supra
7MGTE-swapped from NA...Stock rebuild/Cometic HG
R154 Tranny-swapped from W58
Mines ECU...soon to be megasquirt
3inch HKS
Dropped on K-sport coilovers
Piggy808 is offline   Reply With Quote
Old 12-21-2012, 01:34 PM   #3
pandrade
pandrade is on a distinguished road
every thig you need drift otion now has the new oil cooler and ps cooler and the oil fileter adapter that will let you run a direct system (or the smart way like cre says whith a thermostat)
http://store.driftmotion.com/static/i-bpm-202-28.php oil filter adapter
http://store.driftmotion.com/static/i-psoilcooler.php ps cooler
1987 7m-gte R-154, SS braided clutch line, full 3in exshaust,aluminum radiator,full throttle gen 2 whith GM 3 inch mass air flow,13lbs flywheel, and more to come
pandrade is offline   Reply With Quote
Old 12-21-2012, 07:06 PM   #4
The NA didn't come with an oil cooler, so if the swap on your car was incomplete you may not have it. The stock oil cooler mounts on the driver's side (left) right at the end of the stock intercooler.
Braided reinforcement isn't the same as stainless braided hose. Don't confuse the two. Braided fiber reinforced hose is what you use for pressure rated applications it's available with and without external braiding which is used to protect the exterior of the hose. I used oil hose from Aeroquip and no-pinch clamps on the pipe side. The hose was rated for around 200psi and MUCH more heat than the oiling system would ever see (even if it somehow caught fire)... It's made specifically for this application.
Old 12-21-2012, 08:27 PM   #5
Piggy808
Ok...found it...so I should just leave it alone then? I guess I can run 2 oil coolers...now to look for a new PS cooler.
1991 Supra
3inch HKS
Old 12-22-2012, 05:59 AM   #6
I recommend against running both.... pressure loss and reduced flow = B A D.
Tags
oil cooler, power steering
Na-t oil cooler question? Sonyps307 MKIII Supra 3 11-06-2011 07:40 AM
oil cooler questions??? JohnFurness MKIII Supra 2 03-31-2011 12:25 AM
1989 supra turbo oil cooler hoses Rob1 MKIII Supra 1 02-12-2011 12:55 AM
Egr Cooler, Coolent Banjo slader99 MKIII Supra 6 05-02-2008 06:20 PM
oil cooler supraman121 MKIII Supra 10 08-27-2007 09:23 PM
