Old 09-18-2012, 09:24 AM   #1
lmmr74
lmmr74 is on a distinguished road
Default Oil on the spark plugs
Hello,
I was changing the spark plugs on my 89 Turbo and i realized that they had oil on the base (the are of the spark plug that ignits the fuel inside the combustion chamber), the first thing i thought was piston o-rings, but i did a compression test and everything was fine.
What can be the cause of this oil on the combustion chamber??
Thanks for the help!
LR
lmmr74 is offline   Reply With Quote
Old 09-18-2012, 03:57 PM   #2
Sonyps307
The valve cover seal get old and start leaking down to the spark plug. Then when u remove the plugs the threads and bottom get coved in oil. Check that black cover in the middle to that leaks to from the big 14mm Allen bolts.
Old 09-19-2012, 01:48 AM   #3
Bru
Bone Stock w Upgrades ;-)
Bru's Avatar
I made a cheap tool to tighten down the 14mm allen center galley plugs. I used a 14mm bolt head
in the allen hole and 2 jam nuts tighted together on the threads. you just need to get a socket over the top jam nut to tighten. use decent quality material or else it could break / strip the threads. To sop up the oil with the spark plugs in I used a bent nose pair of tweasers to hold a patch of paper towel.
Old 09-19-2012, 02:10 AM   #4
See the thread in the FAQ section for detailed information on the topic, including pictures.
Help...My spark plugs are in the oil !!! chinesedawn MKIII Supra 6 10-03-2011 09:25 PM
Spark Plugs and Water cgreiner MKIII Supra 1 07-21-2009 03:49 AM
Spark Plugs (1G-GE vs 7M-GE) makemedie Non-Generation Specific Questions 5 10-26-2008 05:19 AM
NGK Spark Plugs 91 Supra MKIII Supra 5 08-07-2007 03:52 AM
1986.5 with blown Head Gasket - Removing Spark Plugs unkymurch Non-Generation Specific Questions 10 03-02-2007 06:48 PM
