Old 08-05-2012, 10:25 PM   #1
Aero
Aero is on a distinguished road
Default Part Number Requests (mostly turbo specific)
So I pulled my turbo this weekend because I couldn't get the wastegate actuator arm to move. After I got it out of the car, there was oil in the actuator, and it was completely froze up. After doing some research, I've discovered that you can't simply buy the actuator, but you have to buy the whole turbo. (And it doesn't appear to be serviceable either.)
Anyway, I've found one for what appears to be a pretty decent deal on eBay:
http://www.ebay.com/itm/270835601531...ht_5155wt_1037
but I need some of the gaskets to reinstall it, and I doubt the turbo listed above comes with any of them. (I messaged the seller to ask, but I'm still waiting to hear back from them.) Anyway, if anybody could help me find some of the part numbers for these gaskets, I'd greatly appreciate it. Here are the ones I need:
exhaust donut gasket (the one from the turbo to the downpipe)
oil line gasket (both the one at the turbo and the one at the engine)
coolant line gasket at the turbo
oxygen sensor gasket
gasket from the turbo to the exhaust manifold
I'm also looking for some of the connectors by the water thermostat housing. A lot of mine have very weak spots right at the connectors where the wires are about to break. For these I need:
the one that goes directly on top (according to my book, it's the cold start delay plug)
the connector for where the oxygen sensor plugs into
cold start injector water temperature sensor
cam position sensor plug
I'm also looking for the little cap that goes over the wire on top of the altenator.
Any help is greatly appreciated, and of course advice is always welcome as well.
Aero is offline   Reply With Quote
Old 08-09-2012, 12:51 AM   #2
I really need to take some time to look through the garage and see what all I have on hand sometime. I have a LOT of MKIII gaskets boxed up somewhere.
You'll find an online version of the Toyota Electronics Parts Catalog here: http://www.cygnusx1.net/Supra/Library/EPC/ It might take a little playing around with for you to get the hang of it but everything you need is there and if you get stuck on one post a link and the reference number and we'll get you squared away.
Replacement connectors/pig tails used to be available through the dealer. I'd go that route over putting in old brittle connectors. Or convert to GM weather proof connectors from NAPA.
Old 08-17-2012, 12:01 AM   #3
Aero
Thanks for the help, as always, cre. I've managed to narrow down my shopping list to a much more workable size. I've gotten most everything I need, but the connectors are still giving me a bit of trouble. If anybody can offer any help with these last few part numbers, I'd appreciate it.
I'm looking for:
-the oxygen sensor connector on the harness side (the t-shaped, 3 pronged one)
-the cold start injector time switch (mine was completely absent when I got the car)
-the little insulator cap that fits on top of the altenator
Also, I need the mechanism for the fuel door latch. I only need the part with the spring that the cable fits into right at the door. The threaded part that the nut tightens on (the nut on the outside, next to the fuel cap) broke on mine. I've managed to narrow this one down to two different part numbers. I'm just not positive which one it is for sure, but I believe it's either 77035-14200 or 77037-90K00. If anybody can confirm either of these for me, that'd be great.
What do you call this part? Part Number? suprajim MKIII Supra 8 02-27-2010 12:57 AM
WTK Part numbers from engine number ravi4001 MKIV Supra 5 01-28-2010 12:34 AM
