Old 07-03-2012, 12:49 AM   #1
pandrade
pandrade is on a distinguished road
Default squeezing the best out of factory brakes
As of now i have all rebuilt callpiers whith oe spec pads and for fluid im running ate race blue,the brake lines are still good, and factory brake booster.
i know to get the best out of the brakes i should get better pads and ss brake lines but does any one know how to get a little better performance from the factory breaks? at auto x i have to hit the breaks like im tryen to break the peddal, while my buddys lexus is350f a small tap and you get full pressure( i know the teck and desighn are decades better) any little tips to optimize factory brakes
maby a new booster from one of the toyota pick ups might help?
share the little tips you have learned over the years
1987 7m-gte R-154, SS braided clutch line, full 3in exshaust,aluminum radiator,full throttle gen 2 whith GM 3 inch mass air flow,13lbs flywheel, and more to come
pandrade is offline   Reply With Quote
Old 07-03-2012, 03:14 PM   #2
You've answered the question yourself already. Pads and new lines (the lines don't have to be stainless braided, just new OEM should provide some improvement). A different master brake cylinder isn't going to do much if your lines, calipers and pads aren't up to delivering the friction needed. If you don't want to fork out the dough for Porterfield pads look at EBC's offerings.... even the red stuff pads offer a significant boost in performance over what you'll otherwise get at the local parts store.
As for the brake booster, I don't recall anyone ever trying to swap in the whole assembly, just different master cylinders. The 4Runner's master cylinder bolts right on and came in a couple different bore sizes. Hit a salvage yard, grab a couple from a couple different years and try them out. I think there were 5/8", 3/4" and 1" bores depending on year and model.
Old 07-03-2012, 05:16 PM   #3
pandrade
yah i imagines this would be the next step, i know the factory brakes will never be as good as my friends 09 is350f but i dident know if there was something i had missed on getting better brakeing( besides stepping up to a full big brake kit which i bet will match lexus or even far surpass it)
Old 07-04-2012, 05:05 AM   #4
Well, there's the dual pot front caliper swap from the Toyota Previa minivan.... but there was never any solid info showing that they worked any better. The contact area really any different as the two pistons were each much smaller than the Supra's one. It is a straight bolt on affair though from what I recall. I'll bet you there's a reason you probably haven't heard much (if anything) about it.
Old 07-04-2012, 04:08 PM   #5
pandrade
never heard of that swap but again im new to the supra world.im just amazed of the brakes the new is350 come whith, 2pice ceramic rotors, and massive callpiers they feel sooo good
brakes dont work in cold weather bassboy3313 MKIII Supra 4 11-21-2010 10:12 PM
MKIII Wilwood 12.9" Rear Brakes With Parking Brake ARZ Arizona Performance 0 08-25-2010 06:34 PM
TT brakes on NA supra TTbrakes MKIII Supra 0 03-06-2009 01:00 AM
Two Issues: Front Brakes and Sporadic Vibration Chambers MKIII Supra 0 11-03-2007 04:15 PM
Brakes 5M Vs. 7MGTE panda-supra MKII Supra 3 03-22-2006 09:07 AM
