Old 06-18-2012, 02:08 PM   #2
pandrade
pandrade is on a distinguished road
I might be able to help since i replaced mine a year ago and i havent leaked since. is it leaking into the interior and carpet or out into the firewall, and also did you properly adjust the pedal play. if your saying its leaking and you havent filled it up any more, it could be a few things but i kinda need to know its it leaking into the the interior or out into the fire wall
1987 7m-gte R-154, SS braided clutch line, full 3in exshaust,aluminum radiator,full throttle gen 2 whith GM 3 inch mass air flow,13lbs flywheel, and more to come
pandrade is offline   Reply With Quote
How hard is the clutch master cylinder to replace? the#1 MKII Supra 2 05-27-2016 04:32 AM
Need Help with Replacing Clutch Master Cylinder xxx609 MKIII Supra 7 02-01-2012 01:36 AM
Clutch Master Cylinder question. 1989 Supra. PFlanagan MKIII Supra 4 08-07-2008 08:20 PM
Clutch Master Cylinder Help please!! ebang MKIII Supra 5 05-13-2007 05:36 PM
Maintenance brake and clutch master cylinder fluid IHateHacks MKIII Supra 1 04-18-2007 07:15 PM
