Old 06-14-2012, 09:23 PM   #1
pandrade
pandrade is on a distinguished road
i think it all depends on how bad your rack and pinion is. when i first got my supra the rack leaked all the fluid in about 5 minits. if this is your case then you could damage the ps pump which would add up to even more repairs.
changing tire sizes wont really do that much of a diffrence unless you go from like a suv tire and rim up front and facotry in rear( for about a year i ran 225 60 16 on the rear and 225 50 16 in front, the rear was way to tall but i dident notice a diffrence, except for traction). when it comes to driving on a bad rack it all depends on how bad it is. Mine would hold alighnment perfectly and steer just fine but i ran the risk of killing the ps pump, how bad is your's? does it leak, one of the ends wont fit the tie rod end; all back to the origonal question how bad and whats damadged about it
1987 7m-gte R-154, SS braided clutch line, full 3in exshaust,aluminum radiator,full throttle gen 2 whith GM 3 inch mass air flow,13lbs flywheel, and more to come
pandrade is offline   Reply With Quote
Old 06-15-2012, 06:33 AM   #2
sd88supra
sd88supra is on a distinguished road
As far as "how bad" it's damaged, I'm not sure. It leaks the power steering fluid in about two weeks though, not five minutes. This is not even consistent, because sometimes I'll notice a small puddle of fluid, and sometimes it won't even leak at all. I top it off once a week anyway.
The alignment itself is fine; I can go fairly straight if I'm driving on a nice even road (not completely straight because the current tires do have uneven wear). However, when I brake on a titled road it moves more to the side than normal, and the car loses more direction than normal when hitting a bump - that's how I know the rack and pinion is bad.
Given what you've said though, I think I'll just swap the tires before my trip and just drive like that for a week. Thanks again.
-1987 5 spd N/A with TEMS: low miles! All stock with the exception of electric fans and an '89 front bumper, Yokohama 225/50/16 with stock rims. It's a mess and in the garage.
-1987 5 spd Turbo with TEMS: miss-matched tires, needs lots of work, but it runs! Project car.
-1988 N/A auto targa: all stock except 18" rims with Falken 265/35/18 in rear and 225/35/18 in front; daily driver.
sd88supra is offline   Reply With Quote
Old 06-15-2012, 05:35 PM   #3
pandrade
if your rack leaks that could be the directonal issue, as a quick fix i would go to the FAQ's and check how to flush the ps system and put in lucas ps fluid whith stop leak( it stoped my leaking for about a month) could be that during a bump you hold the wheel straight but that loss of pressure some where in the system is what causes it to wounder.
that seems like a good option, i wouldent worry about tire wear so much the rack its self doesent cause that other suspension components would, try the flush and lucas see if that is a temporary fix
rack and pinion converson pandrade MKIII Supra 6 04-16-2012 01:55 PM
Any tips on replacing Rack & Pinion on 86 1/2 Supra Norm MKIII Supra 4 08-13-2011 02:52 PM
Fixed Rack and Pinion but steering still does not work 91supraturbobrown MKIII Supra 3 03-29-2011 04:22 AM
Need Rack and Pinion steering unit Ranma MKIII Supra 1 08-11-2010 06:44 PM
Rack and pinion removal fasteddy5000 MKIII Supra 2 04-05-2010 02:16 PM
