Old 06-13-2012, 09:00 PM   #1
Cakes
Cakes's Avatar
Cakes is on a distinguished road
Default Losing power at 2k rpm.
What's up everyone? I have a little problem at the moment that's driving me crazy!
Alright so just picked up an 87 N/A auto, that has been sitting for about a good 7 months. Bought it cheap, an lets just say I got what I payed for. The day after I picked it up I started going through an cleaning/ inspecting what it further needed to get it going till I do a swap. Replaced the cam seals, plugs, wires, exhaust manifold gasket (previous one was blown), an flushed everyhting. Oh also did a thorough inspection of all the lines, obviously. Buuut I screwed up somewhere around cleaning the TB an took off the TPS, after thinking I had set it up properly it doesnt rev past 2k with the pedal but will with the throttle wide open manually, takes a little time though. Afterwards sounds like it wants to stall out under 500, then rises back to 7-800 an idles fines. Actually does everything fine till it hits 2k I've checked this over and over again an can not seem to get it right. I'm at a lose and would like another opinion or two.
Damn almost forgot I have 41 popping up, so is that a new TPS? or am I retarded and can't calibrate it right? I dont see how it could be a short, and I'm pretty the ECU is fine.
Cakes is offline   Reply With Quote
Old 06-14-2012, 01:25 AM   #2
Code 41 is a hardware fault, not related to anything you can calibrate. If you're certain the wiring and ECU are sound then yes a new TPS would be called for. Testing information for the TPS is covered in the TSRM in the EFI section under Throttle Body.
Old 06-14-2012, 02:14 AM   #3
Cakes
Cakes's Avatar
Awesome thank you greatly for the advice Cre. I'll grab a new one and see what happens. Just wanted to make sure before buying something I didn't need.
Old 06-14-2012, 04:07 AM   #4
Test yours, don't just go and blindly buy one.
Aftermarket shifters for R154 trans MKIII? Boombastic Exterior , Interior, and Detailing 4 08-11-2010 04:28 PM
Help needed in first pass at improved appearance finaltable Exterior , Interior, and Detailing 1 06-29-2008 06:34 AM
getaway in stockholm... (i think thats how you spell it) kelogg Road Racing & Autocross 3 06-03-2008 10:53 PM
Feels like losing power. abhattan MKIII Supra 2 06-13-2007 01:47 AM
MEET UP's TEAM_Bastos Drifting 0 03-02-2006 09:09 PM
