Old 06-04-2012, 08:14 PM   #1
Joefishizzle
Joefishizzle is on a distinguished road
Default Tie rod help
So I have a bent inner driver tie rod. Causing bad vibration and bad alignment. Bought a replacement. Just curious any special tools I'll need or if someone knows a good method.
Thanks
Joefishizzle is offline   Reply With Quote
Old 06-04-2012, 08:43 PM   #2
Green7mgte
Supra Forum Moderator
remember the depth..
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 06-04-2012, 08:59 PM   #3
Joefishizzle
Lol well I've never done one. I meant how to do it
Old 06-05-2012, 01:21 AM   #4
pandrade
pandrade is on a distinguished road
i replaced both driver and passanger when i did my rack and pinion, no special tools just mark a line on the rack and on the tie rod to help count how many turnes
1987 7m-gte R-154, SS braided clutch line, full 3in exshaust,aluminum radiator,full throttle gen 2 whith GM 3 inch mass air flow,13lbs flywheel, and more to come
pandrade is offline   Reply With Quote
Old 06-06-2012, 03:32 AM   #5
a400tool
a400tool's Avatar
a400tool is on a distinguished road
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/
1991 MKIII Turbo (Stock)
a400tool is offline   Reply With Quote
Old 06-07-2012, 02:30 PM   #6
Joefishizzle
Alright guys replaced the bent one. Man what a pain in the A$$!!!! However just wanna let everyone know.....a pipe wrench works better than any tool I could find/conjure up. If I replaced the passenger side too. Def would be my tool of choice
Old 06-12-2012, 09:44 PM   #7
pandrade
yah when the old ones are rusty and havent been adjusted in forever a pipe wrench is neccesary( or a torch to heat them up, whith out burning anything of coarse) after new tie rod ends are on you can use a 14mm wrench on the part that u can put the wrench on to do toe adjustments
