Old 05-12-2012, 08:47 PM   #1
sd88supra
sd88supra is on a distinguished road
Question Ignition Issue or Tranny?
Last couple of days (and not consistently, more randomly), I've noticed that while accelerating at around 20mph, 40mph, and 60mph the engine speed drops a bit and goes back up. The weird thing is it only does it in regular mode, not in sport mode.
I was wondering if I should look at some ignition issue (I was thinking spark plug wires) or the tranny. I've noticed it only happens at night, regardless of the engine being warm or cold. Never had it happen during the day.
-1987 5 spd N/A with TEMS: low miles! All stock with the exception of electric fans and an '89 front bumper, Yokohama 225/50/16 with stock rims. It's a mess and in the garage.
-1987 5 spd Turbo with TEMS: miss-matched tires, needs lots of work, but it runs! Project car.
-1988 N/A auto targa: all stock except 18" rims with Falken 265/35/18 in rear and 225/35/18 in front; daily driver.
sd88supra is offline   Reply With Quote
Old 05-13-2012, 02:38 PM   #2
Green7mgte
Supra Forum Moderator
automatic? you can run a tranny diagnostic.
on a side not. My car while letting off the idle will drop rpm's then pick back up and hold at 1.5k even with my foot off the throttle.. did this once or twice, freaked me right the hell out.
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 05-15-2012, 02:00 PM   #3
test your tps. i had a simliar problem on a 86 N/A changed tps and it stopped lurching all weird
http://www.cygnusx1.net/Supra/Librar...ction=FI&P=100
have you pulled any codes??
Old 05-16-2012, 02:37 AM   #4
sd88supra
I haven't ran any diagnostic. I came across a TPS problem before, only it idled erratically.
I'll look at the TPS. Thanks.
tranny issue possibly starworts MKIII Supra 0 07-28-2010 09:46 AM
Engine Run-on Issue gottadiesel MKIII Supra 1 04-02-2009 07:26 AM
tranny o/d issue sharkn MKIII Supra 3 06-23-2006 02:09 AM
Ignition write up.. midwestmk2 MKII Supra 0 06-11-2006 02:56 AM
clutch slip skunk MKIII Supra 11 11-29-2005 08:33 PM
