Old 05-03-2012, 01:40 PM   #1
2fast4u
2fast4u is on a distinguished road
Default mk3 supra intercooler
hello i want a direct bolt on intercooler for my toyota supra. its a 7mgte 1990 turbo. i cant find a direct bolt on. Also whats the benifits of a intercooler kit. another thing is whats a good intercooler brand or please provide the websites.
2 fast 4 u
2fast4u is offline   Reply With Quote
Old 05-03-2012, 03:40 PM   #2
pandrade
pandrade is on a distinguished road
i doubt there are any bolt on kits that arent from greedy and cost a fortune,i could be wrong tho, the benifits are the following 1. lower intake temps= more hp and less chance of detonation 2. better motor response due to better and more modern desighn of the intrcooler 3. better fuel economy 4. way better looks 5. more reliable imo
here are a few sites i know for a spearco stly (our intercooler whith both opening on same side) http://www.treadstoneperformance.com...A+Intercoolers this is a very well know brand a bit pricy tho
http://www.siliconeintakes.com/produ...19c62806802119
heres a cheaper alternative( a senior member posted about this site on a thread a long time ago cant remember who it was tho)
now whith both you will have to costome fab some things to make it fit but they both shoulkd fit in the factory space
1987 7m-gte R-154, SS braided clutch line, full 3in exshaust,aluminum radiator,full throttle gen 2 whith GM 3 inch mass air flow,13lbs flywheel, and more to come
pandrade is offline   Reply With Quote
Old 05-03-2012, 06:17 PM   #3
2fast4u
Default mk3 supra
should i change my stock one. also i need an intercooler that will fit inplace the easiest way without having to fab stuff for it if anyone has directions please help
2 fast 4 u
Old 05-03-2012, 08:41 PM   #4
MJG
MJG's Avatar
I doubt you will find much in the way of direct bolt in intercooler kits, that have an appreciable improvment over stock, that do not require some modification / relocation of structure or components.
http://store.driftmotion.com/static/...rcoolerkit.php
The above link will take you to a kit which is one you may want to consider. The oil cooler, coolant expansion tank and horns need relocation.
Old 05-03-2012, 09:49 PM   #5
pandrade
yah it would be nice for there to be a direct bolt on whith out fabing anything. buy yes there will need to be some fabing and relocating of stuff.
the two i mentioned earlier is the right size but no where near direct drop in( nothing ever seems to be for this car)
