Old 04-13-2012, 10:43 PM   #1
Crop
Crop's Avatar
Default new alternator...now more flash codes.. :(
im rdy to drive this POS into the ocean very soon..... just changed the alternator to figure out idle problem....and now i have a check engine light on....
he's my flash code... flash flash flash (pause) flash.......flash flash flash flash flash...(pause)flash
its a 7mgte 87....original issue has been stalling at stop sign or redlights (unless foot is on gas to keep idle up)...
Old 04-13-2012, 10:46 PM   #2
Crop
Crop's Avatar
would that be a 35?
Old 04-13-2012, 11:13 PM   #3
I don't understand what you mean with the flash and a dozen perods between it and the next five and then (pause) as well.
35 = * * * _ * * * * * _ _ _ (then repeats) * = flash ; _ = 1 second pause.
Old 04-13-2012, 11:33 PM   #4
Crop
Crop's Avatar
i guess im getting a code 35 then...3 flashes, a pause then 5 more, then a repeat.
car seems to stall now when i tap on the gas fast at idle.. it idles at around 500-600 (seems to go up and down between 500-600) ill tap on the gas to bring idle to 1k then let off the gas pedal then itll bog n stall..sometimes it recovers itself from stalling out.
i guess next on my list to purchase with my limited knowledge would be TPS? IACV?
Old 04-13-2012, 11:35 PM   #5
Crop
Crop's Avatar
high altitude compensation sensor? (hac) perhaps?
Old 04-13-2012, 11:56 PM   #6
HAC sensor is an external unit on '87 and '88 7M-GTE MKIIIs. It's a small black box with a three wire harness running to it which mounts to the same support that the glove box hinge mounts to. As long you're not driving at different elevations (see: driving in Kansas versus the Tibet) it should make little difference in actual performance.
Old 04-14-2012, 12:09 AM   #7
Crop
Crop's Avatar
What to do next? Should i just goto mech and let them check codes so i can narrow down the problem? Or try to check the TPS? Im kinda lost on ideas now.
Old 04-14-2012, 04:33 PM   #8
Crop
Crop's Avatar
ok after actually reading up on these ecu codes.. im pretty positive im getting a code 31 and a code 51... MAF and TPS seems like the culprits now....
Old 04-14-2012, 04:34 PM   #9
Crop
Crop's Avatar
*kvafm... thats what i meant instead of maf.
Old 04-14-2012, 07:17 PM   #10
Crop
Crop's Avatar
when i start the car cold it starts idle at around 900-1000 rpm...within about 3 seconds of this idle the check engine light goes on, at that exact moment idle drops to around 500 rpm and starts to fluctuates from 500-600rpms.. if i give it throttle to around 1000 the check engine light goes off, as soon as i let off throttle from that time the rpms drop to a stumbling 450-300 rpms with check engine light back on then returns to the 500-600 rpm range.
i started looking at the TPS connection and removed the wire harness for inspection.. i forgot to reconnect and started the engine..to my amazment there was NO difference in the cars idle or rpm from previous description above.. whatcha think???
i think i might be getting somewhere.. help me plz
flash code help.. plz Crop MKIII Supra 4 03-20-2012 11:32 PM
How to check diagnostic codes suprra_girl MKIII FAQ 10 12-27-2011 08:30 PM
how to do a diagnostic suprra_girl Supra FAQ 40 12-27-2011 08:26 PM
Codes 25,26,51! justin1642 MKIII Supra 11 08-30-2007 08:08 PM
bit sick jake MKIII Supra 1 02-06-2005 12:06 PM
