Old 04-10-2012, 11:06 PM   #1
2fast4u
2fast4u is on a distinguished road
Exclamation mk3 supra power steering fluid
hello ive got a 1990 toyota supra turbo with the 7mgte. i went to oreily auto parts to buy power steering fluid for my car. they told me i have to use dexron type automatic transmission fluid so they told me use dexron type 4. i put dexron 4 no problems or sounds but the manual says use dexron type 2. iam concerned that i might be ruining my power steering
2 fast 4 u
2fast4u is offline   Reply With Quote
Old 04-10-2012, 11:37 PM   #2
It's Dexron VI (6) not IV (4, never existed as a final product. No such thing as V or 5 either.). It is backward compatible but I recommend you fully replace the old fluid. The viscosity between the two is different and while it's still not well mixed in a power steering system you may notice off and on excessive response or resistance. Also, as it's thinner and will have active detergents, if you have a leak, expect it to be worse.
Old 04-10-2012, 11:45 PM   #3
2fast4u
Default mk3 supra
what do you recommend putting in becuase when i did the head gasket i removed the power steering can/filler. there fore when i was done with the head gasket i just filled it up with dexron 6. VI. should i drain and redo it and if so with what kind of fluid.
2 fast 4 u
Old 04-11-2012, 12:32 AM   #4
Oh, they're technically safe to mix so if you've had it in there for a while I wouldn't sweat it. Nonetheless, changing the fluid completely isn't a bad idea.... It's probably never been done before. I would use Dex VI for the lower viscosity, higher shear resistance and lower friction coefficient. I'd change it out a second time after a month or two because all the fresh detergent it likely to loosen up a fair amount of crap.
Old 04-11-2012, 04:07 AM   #5
2fast4u
Default Mk3 supra
If i change it which pipe would be the return line
2 fast 4 u
Old 04-11-2012, 05:58 AM   #6
The return is low pressure... Has constant tension clamps as opposed to crimped fittings.
Old 04-11-2012, 02:29 PM   #7
2fast4u
Default Mk3 supra power steering fluid
Alright. Thanks but what's the difference between crimped and constant clamps
2 fast 4 u
Old 04-11-2012, 04:05 PM   #8
Constant tension clamps aka CT clamps = The spring type phose clamp you use your fingers or pliers (or special tool) to remove and replace. FAR superior to worm gear clamps or regular T-bolt clamps but just below CT T-bolt clamps.
Crimped hoses have a metal cap that surrounds the entire end of the hose. Not to be confused with AN fittings which are hex shaped (the Supra doesn't have any of these stock anyway, so no worries).
Old 04-11-2012, 06:47 PM   #9
2fast4u
Default mk3 supra power steering
they both have those clamps that you use your fingers or pliers. both of the line thats on the canister have those
2 fast 4 u
Old 04-11-2012, 07:15 PM   #10
I'm sorry... I was thinking on the compressor. The reservoir sits in the middle of the low pressure line. I believe you want the one which runs to the cooler, not the pump. http://www.cygnusx1.net/Supra/Librar...spx?F=4503&P=1
No power steering 90supra MKIII Supra 1 11-01-2010 01:17 PM
Power Steering cables wet (leak) question rjSupra MKIII Supra 2 09-20-2010 11:34 PM
94 Supra TT with idling and lost of power issue bayatt MKIV Supra 4 03-12-2010 01:29 PM
power steering wont bleed please help. carnahkt MKIII Supra 5 01-24-2009 09:20 PM
power steering kylesupraturbo Non-Generation Specific Questions 5 01-08-2009 05:19 AM
